Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
How can I remove swirls and water spots out of my BMW i8 ?
Not enough typing time now days to type out detailed replies in e-mails for one set of eyeballs. This is what our forum is for, (it's not a blog but it's okay to call it whatever you want)
Below is a list of high quality tools, pads and product to do the job right the first time. I care not which polisher you purchase, my personal preference is the Porter Cable because I like the fit and finish of the tool overall and anything I want to accomplish using a simple dual action polisher I can do with the PC. If I need more power I use either a FLEX 3401 or a rotary buffer. That said, the Griot's Garage 6" DA is a copy of the PC and most people will agree it has more power and a better warranty.
Which ever tool you purchase, you WANT a 5" backing plate so you can use 5.5" foam buffing pads.
Porter Cable 7424XP
Both of the above are available as HD models. The letters HD mean they come with a Heavy Duty 25' cord pre-wired into the tool so you
A: Don't need an extension cord to work around the cord.
B: Don't need to worry about harming the electrical components by using too light of duty an electrical cord.
C: Preserve the tool warranty.
As Customer Care if interested. 1-800-869-3011
Wolfgang Uber Compound
Wolfgang Finishing Glaze <-- this is NOT a glaze but a fine cut polish, disregard the words used to describe the product it works GREAT.
Wolfgang Deep Gloss Paint Sealant 3.0
Here are 3 brands of thin 5.5" foam pads that will work great on either the PC or the GG. When doing correction work you want plenty of foam cutting pads as clean dry pads rotate best and give you best defect removal. You need less polishing pads and only one pad to machine apply the sealant.
5.5" SUPER THIN FOAM PAD OPTIONS for your Dual Action Polisher
Super thin 5.5" foam buffing pads
The primary benefit to super thin foam pads is that free spinning orbital polishers are able to rotate and oscillate these pads better than thick pads.
What does this mean to you?
You can compound and polish paint to perfection faster than ever before when using orbital polishers like the Porter Cable 7424XP or the Griot's Garage 6" DA polisher.
Currently Autogeek carries three brands of super thin foam pads,
From left to right
Lake Country 5.5" ThinPro foam pads
Griot's Garage BOSS 5.5" foam pads
Meguiar's 5.5" foam discs
And lots of high quality microfiber towels... from this write-up... (look at the pictures to see these towels in action and what show car quality results look like)
1971 Dodge Charger R/T - 1940 Oldsmobile Streetrod shine by Pinnacle
These towels for compounding and polishing
Gold Plush Jr. Microfiber Towels 12 Pack
These towels for wiping off waxes and/or sealants...
Super Soft Deluxe Green Microfiber Towels with Rolled Edges - 6 Pack
My guess is the paint probably needs to be clayed, to find out simply do the Baggie Test
The Baggie Test as seen on Competition Ready TV with AJ and Mike Phillips
Water spots info coming up...
Mike, been reading your blog and want to get some of the product to remove swirl mark and also protect and shine.
What do you recommend for my bmw i8.
Also, do you have anything for water spot?
Porter Cable 7424XP
From left to right
