Do you mind sharing which compound and polish you use? It might help us answer your question specifically for you. Thanks.
Hi Kemefk: Please see below and my earlier post to Mike. BTW, the consensus online about my Simoniz is that it's a rebranded
WEN 2 speed polisher rotary. It's definitely a budget model.
Here's some more info on the products I found on the manufacturer site:
1. Car Beauty Pro R-26 Clear Cut Clearcoat Cleaner
"Medium duty, creamy machine cleaner formulated for use on factory applied and refinish clear coat paints. Synthetic micro abrasives quickly and safely remove new car finish blemishes, acid rain damage, water spots, light to moderate oxidation and 1200-1500 grit wet sand scratches. Leaves a clean, glossy surface that is ready for polishing.CONTAINS NO WAX OR SILICONE. Available in pint and gallon sizes.VOC COMPLIANT.
Meets CARB/OTC Regulations."
PRO Car Beauty Products: P-26 CLEAR-CUTâ„¢ COMPOUND
2. Car Beauty Pro Allura P-8-Q Finish Glaze
"Allura™ Finish Glaze is designed to remove and fill wet sanding scratches, swirl marks and other lights defects after compounding in one easy step.
This body shop safe machine glaze removes 2000 grit & finer sand scratches and other paint defects from all types of paint finishes. Also repairs cob web scratches, micro scratches and swirl marks after compounding. Its non-silicone, non-wax formula buffs fast and easy with very little dust. Natural oils brighten color and restore depth & clarity. Produces a durable, high gloss finish. Safe for all OEM and refinish paints. Light pink in color with cherry fragrance. For hand or machine use. BODY SHOP SAFE. CONTAINS NO SILICONE OR WAX. VOC COMPLIANT.
• Use a high speed buffer with a BV-85-C PRO® Eliminator™ Blue Foam Polish Pad
• Follow with P-9-Q Allura™ Final Finish Wax for long term protection"
PRO Car Beauty Products: P-8-Q Allura™ Finish Glaze
3. Car Beauty Pro Allura P-9-Q Final Finish Wax
"Allura™ Final Finish Wax provides excellent gloss and wax protection on all automotive paint finishes.
This is an easy to use, premium carnauba creme wax developed for body shop use. Formulated to enhance color and achieve an ultra rich, deep gloss shine. Offers safe, long-term protection on all OEM and fresh cured refinish paints. Hides hairline scratches and adds brilliant color depth & high gloss to OEM and refinish paints. Mild cleaning agents remove surface contaminants while offering long term protection for lasting beauty. Light yellow in color with a pleasant banana fragrance. For hand or machine use. BODY SHOP SAFE. CONTAINS NO SILICONE. VOC COMPLIANT.
• For best results, pre-clean fi nish using Allura™ P-8-Q Finish Glaze to remove minor contaminants and condition paint
• Use a high speed buffer with a WV-85-C PRO®Eliminator™ White Foam Final Finish Pad"
PRO Car Beauty Products: P-9-Q Allura Final Finish Wax
Thanks again,
ND
