I'm painting a bumper with gloss black paint. I'm using cheap Rust-Oleum Paint + Primer in-one spray I got from Home Depot. Most of it came out ok, but I have some areas that is running. I tried sanding those areas down and now its hazy and no longer gloss finish.
I tried using rubbing compound (like you would with clear coat) to no avail. How do you sand/smoothen gloss base paint and keep it glossy? Is this even possible or must the base coat just be sprayed perfectly.
