DON'T GUESS!!Yes these are the factory wheels on a TDI jetta. They don't look like bare metal to me. Just wanted to be sure.
I guess they are painted or coated then. Do they need any protective sealant of some sort?
Thanks
If it looks like it's just bare aluminum you can use a metal polish with a microfiber towel and rub it on the wheel. When it pulls any oxidation off it should be black on the towel if it's uncoated aluminum.
I sure hope that's all you plan on doing with D140!!I was looking at the Meguiars D140 wheel cleaner.
Here you go...Hope this helps!What can happen if he does test the metal polish and the wheel is painted or cleared?
That's what I was wondering
How to determine what type of wheels you have?
Re: how to determine what a wheel is made of
Wheels are either made from a material and you're working directly on the material, examples include aluminum and magnesium. Or wheels are coated, so the wheels are either steel or aluminum and have been coated with another type of material and anytime you're working on this type of wheel you're working on the coating.
Magnet will tell you whether it's steel or aluminum, that's a pretty simple test that will tell you real fast the material the wheel is made out of. Below are some tips for testing to determine if there's a coating on a wheel.
•Uncoated or Bare Aluminum Wheels:
-You'll quickly see black residue build up on your polishing cloth
•Clearcoated Aluminum Wheels:
-You might see some dirt residue on your polishing cloth but it won't turn black like you'll see if it's bare aluminum.
•Anodized Aluminum Wheels:
-Same as clearcoated aluminum, you will see a little colored residue come off, usually the color of the anodizing but it certainly won't be anything like what you'll see if you're working on bare aluminum.
•Chrome Wheels:
-You shouldn't see any color coming off chrome except for any built-up roadgrime that didn't come off when you washed the wheel and this will tend to be kind of a dirt color, light brown. After you remove any roadgrime then you won't see any color come off the chrome at all.
•Clearcoated Wheels:
-Since clear paint is clear, you should see no color or pigment coming off on your polishing cloth. If there's dirt or roadgrime built-up on the clearcoated wheel you'll see a little brown color coming off but that will stop once you have the roadgrime removed.
•Painted Wheels:
-If you're wheels are painted a color and not clearcoated then if you rub a little polish onto the rim you'll see the color of the paint coming off onto your polishing cloth.
•Testing an aluminum wheel:
-You can do this same type of test to any wheel using either a light polish, paint cleaner or metal polish. Always test in an inconspicuous area if you think the wheel might be painted, either clearcoated or pigmented paint.
-Oxidized Aluminum Comes Off Black
__________________
Mike Phillips - Director of Training
Unfortunately, you did get the wrong one. That mother's product is for "mag" type wheels that are bare aluminum. For regular clear coated factory alloys, which would be the stock ones on a VW or most all OEM wheels, there are many choices for wheel cleaners. The color changing wheel cleaners such as Sonax FE, 1Z colortec, Meg's Dub, etc, work well for wheels that are covered in brake dust. Good choices for maintenance cleaning are CG's sticky gel or Diablo and are cost effective.
For German cars that tend to generate a lot of brake dust, it's a good idea to put a sealant on the wheels periodically; optimum opti-seal is a good one since you don't have to buff it off, but any good sealant will work.
For maximum protection, use a coating such as Optimum gloss coat or any of the wheel coatings like DP, PBL. I coated my BMW wheels with 22ple and it has made wheel cleaning soooo much easier than before they were coated. I use CG sticky gel and soapy water and they always come out perfect, even the barrels. I typically do routine wipe down with Sonax BSD to make drying easier too.
