How do I care for microfiber towels and prevent shrinkage in the wash?
UltimateDetail
Just recently I realized a lot of my cobra 600 MF towels have shrunken fibers when comparing them to the new ones i just bought. They still do the job, but after using the new ones I realized how much more effort I was exerting with the shrunken ones.. Anyway, my question is, "How do you properly wash and take care of MF towels?" Also, what do you recommend using as a detergent? As I went to go buy one in my last AG order and after reading through some reviews on the forum, I read nothing but negative reviews on all supplied detergents on Autogeek. Currently I use Tide without fabric softener and dermatologist tested detergent( the one in the white bottle). Thanks!:dblthumb2:
I put mine in really hot water to get the containiments out. I let it soak for awhile and the. Put themin the washing machine with a good liquid detergent. Following that in the dryer. I have minimal shrinkage with my MF. Once out of the dryer. I will take a clean pad conditioning brush and run it over the towels on each side to make sure there is nothing solid in them. Just did this with my towels on Sunday.
I've been using DP MF cleaner. I do a pre soak and wash them in the hot/cold water cycle. An extra rinse doesn't hurt either. I throw them in the dyer on low heat.
All my towels still look and perform like new.
I won't expect a synthetic towel to shrink. Maybe if overheated
I'll have to try that and see how it turns out, i'm just worried because I don't want to ruin these new MF's. But that just might work vs. my current process. Thanks:dblthumb2:
after you wash them, hang them to dry (hold them by two corners and snap them out before so) instead of putting them instead of the dryer...
That's a good idea with the conditioning brush. Thanks for the info:xyxthumbs:
I thought it was bad news to hang dry them??:confused:
I read somewhere about dryer balls, works good.
I have two of them in my dryer.
