How do I clean and condition Napa Leather
CyberVette
I presently have a New 2014 Corvette with Kalahari napa leather. My ? Is I want to clean and condition my seats when appropriate. What products are recommended? My seats are vented and I want to make sure I don't clog the pores and leave caked in material. Any info would be greatly appreciated.
Check your owners manual. I'm not real familiar with the seats in the new vette, but I suspect they are a coated. If the owners manual tells you to clean with mild soap and water that is a dead give away. Do a google search on leather car seats, autotopia has a great thread on it from Todd Helme
My ? Is
What products are recommended?<<<No leather "conditioners"!!
Kalahari is just one of four interior colors...
It's the leather to be most concerned with.
(At least it's not Suede/NuBuck)
BTW: We have perforated leather seating areas in our 2002 & 2007...
that are still not clogged after all these years.
So...Rather than going into much detail...(or suggesting the use of the search function)
I'll suggest going to an expert on leather care...either by PM'ing; or by visting LTT Leather Solutions.
That expert is:
http://www.autogeekonline.net/forum/members/judyb.html
An example from this posting of hers (w/my highlighting):
http://www.autogeekonline.net/forum/auto-detailing-101/58671-how-often-clean-leather-seats-2.html
CLEANING PROCESS
Keep your leather clean by protecting it with a leather protector and then regular cleaning.
Adding 'conditioners' which generally contain oils and waxes will change the appearance of your leather over time as dirt will build up on the surface and cause a sheen.
The routine for correct care should be
Protect from new (Auto Ultra Protect)
Maintain with a regular clean or maintenance product (Auto Ultra Maintain)
Deep clean with a foam cleaner once or twice a year (Auto Ultra Foam)
Simple steps of cleaning & protecting will prolong the life of the finish on the leather
Hope this helps
Judyb
Also:
:welcome: to AGO!
And have FUN with your new Corvette!!
Sonax leather foam is napa leather safe use it all the time.
I use Swissvax leather care kit. It can get pricey, but works very well. If you're going to spend the money on Napa leather, then consider spending a little bit for a good leather care product.
I am sure there are other great products out there. This is what I use.
Dead give-away that it is coated or non-coated leather?
First, welcome to AutoGeek. Second, I second the suggestion to read your owner's manual which will have information on cleaning and maintenance of your leather seats.
That it is coated leather, which is my guess anyway. Very few cars have uncoated leather these days, Ford King Ranch was in the first couple years and had all kinds of problems. If they are coated, most manufacturers will recommend mild soap and water for cleaning. This is also why many cleaners/conditioners made for actual leather leave a greasy feel, they cannot penetrate into the coating like they would leather. Most cleaners and conditioners now days are actually made primarily for the coating, not the actual leather which they never touch.
Best way to tell if its coated put a drop of water on the leather if it doesn't soak in its treated.
Steam is best, can help remove minor stretches and tinkles. But if you don't want to invest in a steamer a high quality leather cleaner is next. Aggressive side CG is great (removes silicone dressings some dealerships put on). Gentle side, probably a PBMG product (not too sure as I haven't tried).
A little trick to keeping seats clean, once a week wet a microfibre (water) and wipe them down. I do that to my C63, 1794 edition Tundra and Lexus. Works wonders, stops blue jeans from staining. Then once every month or two use a cleaner to deep clean. A good technique for perforated leather is to ball up towel, spray cleaner liberally and wipe.
+1
+1
Thank you all for the information you posted. My real concern is keeping my leather clean and new. The light color is a bit of a concern for me as well as the dash being leather coated.
Leather Master makes specific products for uncoated/nappa leather...Autogeek sells them.
One of my cars has while coated leather. I use Leather Dye Transfer Cleaner by Leather Masters to remove color transfers (jeans, etc.) from the seats.
I use Meguiars APC to clean my leather, and then Ultima Interior Guard Plus to protect the leather. UIGP is nice because it does not leave any gloss or change to the surface of the leather.
hope this help.
I think this is some much needed information around here. I knew some of this a few days ago, but after a heated argument on another forum I had to consult the professionals. This is what you should know about Nappa leather and coloring products for leather.
I'm happy to go over the information I gathered on leather care and the best products. I'll add to this post in a few days with that info, but be prepared, Leatherique leather care is not a favored product.
Alright here we go. I spent the past day emailing and calling a few professionals over in the UK that I had seen immaculate, OE type leather refinishing from. I've been cleared on many points, some were right, some were wrong. Hopefully everyone learns a little something from this. I may be using bits of knowledge that were already mentioned here, but this is meant to be a complete understanding.
Now, let's get a little basic background on how leather is made. The leather in question; BMW Nappa.
The leather is drum (VAT) dyed a matching color to the pigment color that is sprayed on later in the process. After the pigment, a clear coat matte (top coat) finish is sprayed on. The true dye process is not always done before color (pigment) coat and top coat are added. This depends on leather type and manufacturer.
What is leather dye and what is pigment?
-Dye is exactly what you would think a traditional dye would be. It stains, it colors, it soaks into the leather and changes the color throughout.
-Pigment is essentially paint. Modern leather pigment is a water based flexible "latex" acting type paint. If you sprayed it on smooth plastic (like a bag or acrylic panel) it wouldn't change the color of the plastic (like a dye would), it would leave a top painted finish. A pigment does not soak into the leather like a dye does. It "paints" on top of the leather attaching itself to the prepped finish.
What is the top coat?
Top coat is a protection coat to the color (pigment [paint]) coat. The finishes can vary from gloss, semi-gloss to matte. A top coat extends the durability, color, and life of the color coat by years and years (if proper care is taken). It also defines the total look and even feel of the leather. Top coats are also a paint, using the same technology as the color coat (polyurethane is one type).
Are there different pigment and top coat types?
Absolutely. Leather Clinic uses a water based Polyurethane type of formula. Leatherique uses a water based complex co-polymer formula. Each company will have their own formula.
When is a dye used?
Dyes are used (not always though) as part of the process leading to the color and top coat of modern leathers. It's also used in older methods of leather color as a stand alone method (ie; no color or top coat after).
How long does a color coat last alone?
The professionals say a color coat is only good for just a few years by itself at best.
How long does a color coat with a top coat last?
A color coat with a proper top coat can extend the life of the finish at least 3 times longer. A frequently used refinished leather would last 1-2 years with just color and at least 4-5 with a top coat added. The professionals say expect 5-7 years with a top coat and even longer if you're super careful and proper care products are used. Remember, a top coated leather is exactly how (nappa as an example) leather rolls out ready for upholstery. Some of us have 14 year old Nappa (like I do in my 96 M3) that is MINT.
What I was wrong about?
I had known Nappa leather was dyed and I have known that the leather had a top coat. I did not know that the leather had a color coat after dye. I also did not know what the color coat was... it's a paint, and "latex" in nature. The color coat is not a dye.
Nappa Leather - OEM Process, Restoration, Color Change Information [Archive] - BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
Leatherique (older style) or Leather Master would be the ticket. Use foam to clean, and brushes to help agitate
