How do I remove brake fluid from carpet
Ted Y
I just got a message from a mechanic friend who I've done lots of work for. He said there is brake fluid on the carpet of a 1967 Corvette he is working on. I have NOT seen the carpet yet. I don't know the carpet color, amount, etc.
I know that brake fluid is essentially hydraulic oil. What products should I start with? I'm thinking start with an all purpose cleaner and go from there. Has anyone got experience with this?
I have a steamer, hot water extractor and a carpet brush attachment for my Flex at my disposal.
Thank you!
Ted
Ted I've gotten oil out of a carpet with McKees 37 carpet pre treatment. I wrote a review on this site and McKees site. Have a look, and a try - this stuff I swear by.
ScottH
ScottH
I actually have some of that. I'm going over to take a look. If forum worthy, I'll attach some photos.
The thing that cuts brake fluid is water. Just use water first with an extractor then use a carpet shampooer after that. The only thing you didn't say if it was Silicone Brake fluid that many Vette owners use. That may be a different story.
The brake fluid has probably soaked
down into the padding, sound deadening
material, and the floorboard. (Hope none
has landed on any part of the birdcage.)
IMO:
It'd be best to pull everything from
the floorboard up; clean the carpet
out of the vehicle.
Also:
It's quite difficult to clean the padding
and the other underlying components.
They may need to be replaced.
{Cover all the bases in a mid-year}
In my experience hot, soapy water will help with brake fluid.
