I was thinking about this and came up with a different plan that will work for some.
A 2 car garage and I need more garage space.
When it comes to washing, I have 2 12x12 canopies and I'm not a fan of having extra buckets, cinder blocks or sand bags to secure them while they're up.
My solution *plan for the weekend* is digging a few holes at the edge of the driveway. Here is what will be used for each of the 6 anchor locations around the driveway.
- 1'x1' and around 18" deep
- STAINLESS eye bolt with a 1/2" eyelet hole ; at least 9" thread length
- 4 stainless nuts
- 2 stainless washers as big as you can buy *Fastenal had 3" in stock*
Thread the first nut within 1" of the eye, add a washer, then a nut to lock the washer in place.
Same process again, but near the end of the threads of the eye bolt.
After digging the hole, use some cardboard with dirt on the back to form something close to a square for the hole.
I have a stick of rebar to feed through the eye bolt and let it hang in the hole about center of the square, but anything thats solid to feed through the hole and support the bolt will work.
Quickcrete mix to fill in the hole to encase all portions of the eye bolt, but the head.
The square has a divot which allows the eye bolt head to be recessed from the surrounding ground height. * I did this so it wouldn't catch a blade when I mow the grass*.
With the bolts being stainless, no rust worries! Use climbing rings to hook to the eye bolts and the canopy. DO NOT use the cheap snap rings people use as key chains in various colors! They are cheap for a reason, and will fail!
Rope to secure between the hooks and canopies. The in-ground cement isnt likley to move in the Oklahoma wind. When a wind does come along to move that block, best be worried about getting into a storm shelter.
photos Saturday or Sunday to explain things better.
chris<pixelmonkey>
