Fishincricket
- Dec 4, 2012
- 622
Let me make this simple. Wax does not bond to the clear coat, it sticks. Even using pristine wash methods ,wax will break down. Since wax is greasy in nature, dirt and grime will embed into the wax layer causing the finish to dull. Over time, washing will produce swirl marks. Normally, most hobbyists apply more wax which is a temp solution, and then swirl mark removers with more wax by hand. Then they realize that is not working, so compound, polish, or a polisher will be needed.
When will correction not be needed is my question? Answer : never. As long as you use wax this will be a problem you have live with. Once corrected, and re waxed it is just a matter of time before this same thing will happen again.
The above is a statement made on another forum that I am a member of. I'm just curious as to how you would respond to this?
Oh, and make no mistake, it's the beginning of a sales pitch for a sealant/coating that he claims lasts for years and won't "swirl" like waxes and sealants.
Seems like a fundamental misunderstanding of how swirls are instilled and how wax works, eh? Just help me with the words, if only to help those reading his words who contemplate investing $50 in his particular flavor of sealant/coating, with the promise that they'll never have to correct their paint again! :doh:
