MrOneEyedBoh
Active member
- Mar 3, 2013
- 1,198
- 1
How do you guys clean wax applicators? I cleaned them using APC/ megs degreaser and they are dusting now that they are dried. I can't see tossing after one use...
For both foam and mircofiber applicator pads, I just wash them by hand with dish soap, rinse well, then air dry.
3d Towel Kleen Diluted 5:1 in spray bottle
Spray liberally onto polyfoam applicator
allow Towel kleen to dwell for 10-15 minutes
put on nitrile gloves and gently rub in circular "wax like" motions on side of sink
Rinse thoroughly in warm water
Take microfiber towel, wrap towel around poly-foam applicator or hook and loop applicator pad, squeeze into towel to remove any additional wax/sealant.
I typically rinse them out again just in case there is any soap residue remaining but I'm not sure this is really necessary
Also, I use the same procedure for AIO polishing pads when trying to remove HD Speed or Poli-seal.
On a side note, I like to blow my pads out with compressed air before I use them. Just like you would do with a microfiber pad to remove any dried soap/compound/paint residue that may not have been fully removed during the washing process. Plus it fluffs the fibers back up. I quickly do the same thing with my applicator pads
Do you think the cheap ones are okay? I've seen some cheap ones but afraid they will scratch the paint. I guess check them in a CD first?
You guys certainly have some good cleaning techniques. Let me throw a different spin on this. If you're using an actual "wax", and can keep the applicator clean (not rubbing against dirty trim, car is clean and deconned, don't drop it), I just put the applicator in a plastic bag, or some wax containers you can squeeze the applicator in there, and just use it again without cleaning. This also works for WOWA sealants.
Another way is to get cheap applicators (they are out there, online) and throw them out after using them or if they get dirty. I've turned to these alternates because washing foam applicators is such a pain, but I still do it, I just try not to do it as much.
All of that being said.....
Setec may be onto something with his recommendation of throwing them into a ziplock rather than cleaning them every single time. It's certainly worth a shot!
