snellvilleauto
- Mar 23, 2012
- 443
I tried M105, Menzema IS1500, D151 by hand and Flex rotary but non work. Suggestion?
i got some off with ultimate compound with orange pad no problem. Maybe the scratches are too deep? Wet sand then compound and polish?
To the OP:
Are you referring to the "Mirror" itself?
Yes, it's the mirror itself
Thanks Corey for the tip.I've seen Scott (killrwheels) mention using Novus plastic polish on them. I have used Novus to great success by hand on interior clear plastic of console but never tried it on that mirror coating material. It's pretty cheap from amazon. A one, two, three step formula. Maybe PM Scott and see if he still recommends it as it was 2007 that he made mention of it's use for this application.
You used 105 on a mirror and a rotary? I would think that it would add more scratches. Maybe Ceri Glass..Dunno.
Ahhh, so if it's that hard i doubt the Novus would work. Maybe Ceriglass. I haven't used it on mirrors but will look into an answer on that if someone with direct knowledge of its use in this application doesn't reply to you. Those scratches do look awful deep though.
