Other things like this are glued in headliners and plastic radiators. Not meant to last.
I have a 57 Chevy and a 72 Suburban that does not have that radiator leak problem. I don't know what to say about that.Yow, plastic radiators not meant to last? Obviously you are not a GM man from the days before plastic radiators...you could guarantee that the upper radiator connector would leak where it was soldered to the tank by the time the car was 5 years old.
Plastic ones never leak at that joint, mostly because there is no joint, it's molded in one piece. It may be that Aluminum core/plastic radiators can't be repaired (or that they could be, but there are no radiator shops anymore, and it's cheaper to replace than repair because of Chinese replacements), but I've never HAD to have one repaired.
There may be a lot of cheap stuff in cars today, but some things I don't miss are:
Brass/Copper radiators
V-Belts
Distributors (and timing adjustments, point/dwell adjustments)
12,000 mile tuneups
Hoses that would blow if you didn't change them every 4 years
Steel exhausts that would rot out every 3-4 years
Transmissions without drain plugs
Chassis lubrication
Worrying about changing PVC valves
Overheating in stop-and-go traffic because there were no electric fans
2-valve heads where the plugs went in on the side and "sure I could change that back plug if the engine was out of the car"--and finally getting it out and it doesn't match the rest of the plugs and you realize the last guy didn't bother
Oh yeah...carburetors and having to warm up the car so it wouldn't stall...for that matter...how about having to get out the can of ether if it got below 5°F?
/rant
Some things gave improved on new cars, but a lot of things just aren't as well made, and the best explanation for that is that most people don't keep their cars long enough for those things to go bad...big 3, Toyota, Nissan and Honda seem to just want a car to be very functional for 10-15 years.
Those are usually covered with a vinyl tape, or, that IS black vinyl tape you are looking at. I treat it like vinyl or rubber trim. Formula 303 Aerospace is an excellent choice, I think. I have seen those areas where the tape has actually peeled off of the door, so you can see it is a tape or film, and not painted.
Well, you removed the oxidation from the surface of it, which revealed the original color underneath. The vinyl is only so thick so you can't keep doing that forever, but I don't think any major damage was done after doing it just once or twice. Now you need to protect it with something.The piece looks just like oxidized black paint so I couldn't resist running my DA polisher with an orange pad and Megs 205 across it just once. It turned the pad black and really made the trim look nice after only one pass.
Could I damage that trim by doing that?
