This is for Hybrid...
Storage and Use:
Ensure that you have sufficient product to coat your vehicle. For cars up to and including a medium estate car i.e. a BMW 3 series touring, 30ml is sufficient but for full-sized cars including 4x4s and SUVs you will need the larger 50ml bottle
EXOv4 can be applied as a stand-alone sealant or as a top layer for Gtechniq C1 Crystal Lacquer or Gtechniq Crystal Serum Light (CSL) - we recommend applying C1 or CSL as a base coat for easy to mark and dark paints
If you are applying over C1, EXOv4 should be applied more than 2 hours but less than 12 hours after you finish the C1 application
If you are applying over CSL, EXOv4 can either be applied straight away after you have finished applying CSL starting the process at the same place you did with CSL and following the same order of panels you did with CSL, or it can be applied up to 24 hours after finishing the CSL application
Ensure that your vehicle is out of direct sunlight but warmer than 5 degrees Celsius, is completely dry and will stay dry for at least 12 hours after application
If needed, polish your paintwork either by machine or by hand to remove any imperfections
Wipe down all surfaces using Gtechniq Panel Wipe and a Gtechniq MF1 ZeroR Microfibre Buff Cloth (apply the Panel Wipe to the cloth and buff, not directly to the panel) if you are applying over newly applied C1 or CSL, this step is not required
Put on the nitrile gloves provided
Drop several (between 5 and 10) drops of product onto the applicator provided. Work the liquid into the pad to get an even saturation
Apply with applicator provided in overlapping strokes to an area roughly 2' x 2' (60x60cm), or work to the bodylines of the vehicle
If the surface of the vehicle is between 5 and 15 degrees Celsius, wait for two minutes and then fold your first MF1 twice to form a square, spread and remove most of the residue using a light touch. If the surface is between 15 and 25 Celsius wait for one minute and for temperatures above this, remove immediately
With your second folded cloth remove all remaining residues. We advise moving your head so that you get direct and oblique views of your finish to spot all residue. It is also advisable to use bright, but flat lighting, to make residue spotting easier
Once you have finished coating your vehicle we recommend repeating the process starting from the same place as you did for the first layer and coating panels in the same order so that you coat your entire vehicle with two layers of EXOv4. You do not need to wait between applying the first and second coating but it will not make it harder to apply the second coating if you do leave a much longer interval between applying the first and second layer
Allow the coating to cure for at least 12 hours before getting wet
We recommend allowing at least one week pass before washing your car
You will find that your vehicle is significantly easier to clean and whilst EXOv4 has significantly better resistance to caustic wash chemicals these chemicals will shorten the lifespan of any coating and are not recommended as part of your care routine
EXOv4 can be overcoated with other products, but if this is done you will get the surface performance of the product you overcoat it with and not EXOv4
An unopened bottle of EXOv4 has a 12-month shelf life from the time of purchase
Store opened bottles in a dry and cool storage area that's out of direct sunlight
We recommend only using opened bottles within three months of opening
