[FONT="]Hey guys, I'd like to minimize introducing swirls as much as possible in the washing process.[/FONT]
[FONT="]I usually don't do the "2 bucket washing method" because I had the idea that a scrub on the grit guard would not get all the dirt off plus I think it would take more time washing this way.[/FONT]
[FONT="]A while ago I bought around 25 of the "The Rag Company" microfiber towels to use for rinseless washes. I don't do rinseless washes anymore and since I bought a pressure washer my current method is:[/FONT]
[FONT="]If the fibers are somehow hardened because of softener residue or burned on the drying machine I wouldn't want to risk the paint. I was thinking on upgrading to using the same method but instead of using several towels, using several of the best wash mitts in the market (I'm leaning towards MF madness incredimitt because of the reviews and since my dry me crazy towel is still soo good)[/FONT]
[FONT="]I currently use around 10 towels but I was wondering if with the incredimitt I'd need less.[/FONT]
[FONT="]They are 25 bucks each and somewhat expensive compared to other cheap mitts, but I don't care too much about the price since I invested probably thousands of dollars worth of time doing a full paint correction (claying, compound, polishing, sealant). If a set of good mitts would delay as much as possible doing this process all over again I think is worth it.[/FONT]
[FONT="]I also use Meguiars ultimate fast finish and Meguiars "hybrid ceramic wax" as sealants around once a month after washing.[/FONT]
[FONT="]How many wash mitts do you think would be ideal for washing a medium sized car reducing swirls as much as possible? Do you think there are other mitts or other methods that would be better for avoiding swirls?
Or should I just go with just one incredimitt and grit guard insert and two bucket method and will I get the same results as using multiple mitts since I'm still dragging dirt on the paint (stubborn dirt that sticks on paint after pressure washer) even when the mitt is "100% clean"
[/FONT]
For example I'm not sure if using 5 mitts (10 different sides) without never dunking the mitt again in the bucket with soap/water would make it any safer than just dunking 1 mitt in a bucket every few panels? (and probably dunking more than 5 times depending on how much dirt is in the car).
In one way I have 10 completely clean sides but with just one mitt I keep dunking in the bucket(s) I could have 20 or more semi-clean sides so sometimes it kinda makes sense using just one mitt (but it probably would be less time efficient)
For example, even if the mitt is completely clean, it will have a lot of dirt in just one 1 ft swipe on that dirty door or fender so the second swipe or even the second feet of that first swipe would probably already be worse than the semi-clean mitt after dunking in bucket.
I already have several buckets so another option could be instead of the traditional "2 bucket wash method" (one rinse bucket and second wash bucket with soapy water), I could do something like a regular wash (one mitt and one bucket), but using 2 buckets and 2 mitts, treating each half of the car as a different car so water is not too contaminated by the end of the wash.
Something like (after foaming, pressure washing loose dirt and re-foaming):
I also could quickly blast each side of the mitt with the the pressure washer before dunking the mitt in the bucket if that helps (this wouldn't damage the microfibers, would it?)
Then repeat the same 7 steps with the other half of the car with a fresh mitt and clean soap and water? [FONT="]Seems like a lot of steps but don't think it would take more than 10-15 minutes doing the 14 steps.[/FONT]
Also, is it true that adding a little of ONR on the bucket would help keeping the dirt at the bottom?
TL;DR:
Not sure which method would be the safest:
1) Using and X amount of "disposable" mitts that I throw away after using and later on throw them in the wash machine (and my question is how many incredimitts would be ideal for a medium sized car)
2)The "2 bucket wash method"
3)2 or 3 times a regular "one mitt, one bucket" method, treating each section of the car as a different car so water in the bucket doesn't get too contaminated (and my questions are if blasting the mitt with pressure washer before dunking would help and if it wouldn't damage microfiber and if adding ONR would help in keeping the dirt at the bottom).
- Foam cannon, rinse to remove biggest dirt, foam cannon again.
- Soak around 10 TRC microfiber towels in a bucket with soap and water and then use each side of the towel for a small section, then throw it to a "used towels bucket", grab a new towel for another section, and repeat.
- Use a leaf blower to dry, sometimes I use a little a "Dry Me Crazy" drying towel without dragging too much and with no more pressure that the weight of the towel itself.
[/FONT]
- Wash with mitt half roof, half hood
- Dunk to release some dirt
- Half trunk, half of each bumper
- Top sections of fender, door, quarter panel
- Bottom dirtier sections of fender, door and quarter panel (possibly dunking even more often after each couple passes if car is too dirty in these sections)
TL;DR:
