How much better is 2 coats of wax than 1?
Luke
How much better is 2 coats of wax than 1? I am using Liquid Souveran on a white car. Does it make a difference to put 2 coats of wax on? If so, how much? Will it last longer?
there is a point of diminishing return on all detailing products. What most would offer is 2 coats of a wax for maximum coverage, and 2-3 coats of a sealant for best durability and protection. Other than that, your likely just wasting time, money, and product.
It is all personal preference and this is not something we can test easily. Whether or not you can tell all depends on how good you can sense things like that and maybe how bad you want to see something. Sometimes it makes a big difference, sometimes not. I say 90% of the look is in the preparation (polishing and such), so another coat won't significantly make things look magical. Lasting longer, I don't really know but you need to make sure you "spit shine" the second coat. Put some QD or water in the fridge let it get cold, then spray some on the surface to "freeze" the previous layer, so you can apply the next. Probably won't work with a PC.
Thank you both for your opinions. Do you think there would be much of a difference though with 2 coats?
Like my sexy car though? Turns you on huh? Umm, akward...
To me two coats is needed (wax or sealant) simply because you will likely catch areas that you missed initially. More protection? That debate will go on forever.......
Miss areas? I have never missed an area while waxing. I go over the area multiple times though. Spread wax, turn speed up and go over area slowly, and then go over area again a little bit faster.
Agree, I usually do two coats of a sealant and two coats of a wax not really for look but more so to ensure coverage. Normally I would think multiple layers of a wax would deter from the look sometimes or show no gain, but somebody on another board had posted pics of a silver S2000 I believe that had something likre 8 coats of some kinda Zymol wax, and it looked pretty damn awsome, never seen silver have the look that car did....maybe it was just that wax?
Obviously you are more careful than I . It seems that no matter how cautious I am there are always tiny spots here and there that were somehow missed....which is why I do it twice. My point is that it is necessary for ME and perhaps others not as diligent as yourself.
i dont mean to highjack, but... should you seal then wax or visa versa? just looking for the little extra...
Seal then wax!:)
In my experience Max Wax and NB both are noticably better looking after the 2nd coat. With 476 I noticed only minor differences with a 2nd coat applied.
NB?
Do you take off the first coat of wax, and then layer on another one?
the more wax the better i try to put a coat of wax on whe ever i get a chance before i sold my other truck i must have had about 50 coats of wax on that thing:righton:
