How much Reset for Kwazar foamer
Texchappy
Just got some CarPro Reset. I’ve had a Kwazar Venus pump up foamer for a while but haven’t had any soap that was foam friendly. How much Reset should I add to it full of water for best results?
How many ounces is this foamer?
Your going to foam your car with a Kwazar?
My IK 1.5 takes 2-3 ounces of soap and I usually have to pump it up 3x's and it's quite a work out. Now the foam is pretty thick for a non-foam cannon and puts it down thicker than my CG's foam gun, but then again the same result is achieved either way. This gives me the option to change it up or maybe down the road just use my IK 1.5 for wheel cleaner only, nice to have options
When I looked it up, it said it was 2 liters.
Keep pondering getting a pressure washer but not sure how often i’d use it. The pump will let me play with foam to see if it interests me at all.
Start with one ounce, if not enough foam go to two ounces. I have no idea how Reset will work on that, it works well on a foam cannon.
Having said that, I got tired of foaming and mostly just wasting soap. I just rinse the car with water now and proceed with the bucket wash. If it somehow gets super dirty, then I might foam it but I might have done that twice in the last year or two.
Personally I only use Reset in my 2BM but if the car is only dusty I guess Reset would be ok. I have other soaps for pre-wash or pre-washing being the only wash as in foam/dwell/rinse/dry only.
I was going to get some Lift but it wasn’t in stock when I ordered. Haven’t invested too much into shampoos etc because I really prefer rinseless.
Gyeon Restart is a great alternative if Lift isn't available. I put 1.5 ounces in my CG's foam gun and foam away, let dwell and rinse away and you can literally "see the clean". I have to use a foam gun because I don't have a pressure washer but the garden hose/foam gun does the trick for me.
