How often and what order?
Mydnyghte
Member
A couple weeks ago, I heavily detailed my car for a show. Washed it, used some Paintwork Cleansing Lotion, then hit it with XMT 360 and topped it off with Souveran Paste. Oh man, it was shimmering:cheers: I was fully impressed with the 360, though there were still some minor swirls left behind. So I ordered some XMT #2. Now, I am kind of confused as to what I should or should not do. What would be the best order to use the afformentioned products? How often should I use the cleansing lotion?
I've also got some intermediate swirl remover that I purchased awhile back when I bought the Pinnacle Twins kit, how does that compare to the XMT #2? I ask because I tried the XMT and it actually left some small swirl marks behind:(
when using the 360 (all in one) or polish (xmt2) you can skip the paint cleanser as wanted. You are abraded the surface versus chemical cleaning. Then top with wax. I would offer that Pinnacle is slightly more abrasive than XMT.
Unless you use it regarding the looks it gives. as said above, not needed after 360 or #2.
