Detailed Josh
- May 8, 2013
- 101
I was wondering how often/safely you can apply an AIO? I know you can only do actual multi-stage compounding, polishing, and dedicated waxing (which I know is not the abrasive step of these 3) so many times as you remove the clearcoat film thickness each time and risk hazing or worse burning through. So what about AIO's? I know you can use a less aggressive pad, but by its nature isn't it still abrading the surface regardless? For your own vehicle, or more importantly eventually a business point if you have a repeat customer would you want to eventually switch to a dedicated wax product for doing one steps if you do AIO's to the vehicle? For example I like Meguiars D151. Would it be wise to use say the Synthetic Wax D156 eventually, or am I being paranoid thinking the D151 will eventually take down the clearcoat after repeated uses over and over even with a less (grey or higher?) pad?
