Flash Gordon
- Feb 6, 2010
- 11,412
- 434
Answer:
The frequency with which you should wash your car depends on several factors:
- Environmental Conditions:
- Urban Areas: If you live in a city, where there's a lot of pollution, dust, and road grime, you might need to wash your car more frequently. Weekly washing could be advisable.
- Coastal Areas: Salt air and sea spray can be corrosive to your car's finish. Washing every one to two weeks can help prevent salt damage.
- Rural Areas: Less pollution might mean you can get away with washing your car every two to three weeks unless there's significant dirt from unpaved roads.
- Weather Conditions:
- Rain and Snow: After a storm, it's good to wash your car to remove salt and debris. If you live in snowy areas where salt is used on roads, washing after exposure significantly helps prevent rust. During winter, washing once a week or immediately after salt exposure is beneficial.
- Dry Weather: In dry climates with minimal dust, once every two to four weeks might suffice.
- Usage:
- Daily Driver: If you use your car daily, especially in harsh conditions, aim for weekly washes.
- Infrequent Use: If your car spends more time parked, you might only need to wash it every month or so, depending on how it gets dirty.
- Bird Droppings, Bugs, and Tree Sap: These can damage paint if left on the car. If your car encounters these, you should clean them off as soon as possible, regardless of your regular washing schedule.
- Car Cover: Using a car cover when parked can reduce the need for frequent washing since it shields the vehicle from dust and environmental pollutants. (HOWEVER, you never want to install your cover if your car is dirty. Doing so can scuff the paint. Further, it's advisable to have a friend help you install to prevent marring).
