nguyenphananh
- Jul 3, 2017
- 4
HI, Im about to apply Gtechniq Crystal Serum light on my cars (1st time doing this), I have few questions from the instruction that I was not totally understand.
1."...Soak the application pad with two full measures from the pipette and work the liquid into the pad to get an even saturation...
....Apply with applicator provided in overlapping strokes to an area roughly 2’ x 2’..."
So after applied 2 full measures from the pipette, I work onto the paint surface in a small 2x2 area, then I REAPPLY ANOTHER 2 FULL MEASURES FROM THE PIPETTE before continue to the next area (let say the hood/bonnet), or do I apply 2 full measures from the pipette ONLY 1 TIME, then work from 1 area to another, without add more CSL, for the whole hood/bonnet??
The bottle is only 30ml, if I use 2 full "pipette" for every small section, will it be enough a mid side sedan??
2. Can I do 2 coats?
3. Can I put regular wax on top of this ceramic coat (once it is completely dried)
4. The instruction mentioned using other Gtechniq products to clean, degrease before applying the crystal serum light.... can I use other non-gtechniq products (which I already had) to clean, prep ??
5. Last but not least: the instruction mentioned after applying the coat, removing the residue with microfiber..... how long do I wait after applying the CSL before wiping off the residue?? do I apply and wipe off right away? or do I wait 5,10....min before wiping the extra off?? and if I want to do 2nd coat, how long do I wait before applying 2nd coat??
Thank you
Thank you
