how to apply Poorboys....
mjc189
I have been reading and understand pro polish is pad dependant and could remove some micromarring. If I use PwC or PwS with a DA if I work it too long or use too aggressive of a pad will I lose the sealant/ carnauba properties? thanks
Yes the PP is pad dependent and depending upon what pad you use you can remove significant swirls with it (very versatile).
If you use the PWC or PWS with say a light cut pad and work it in good then you do lose most of the protection that it would leave behind but it you do a one step with a white pad then you have that protection left behind.
If you have it why not give it a try according to the manufacturers directions and see if it meets your expectations?
thanks for the info!..........now lets see how I do this weekend...lol
