Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
How to avoid overspray when applying a tire dressing
Most tire dressing, (not all but a lot of them), come as a spray, either a pump spray or an aerosol spray. The issue a lot of people have when applying them is how to avoid getting overspray all over the wheels or surrounding body panels.
Here's a real simple technique to take all the hassle out of applying ANY type of dressing be it a spray, lotion, gel, aerosol, etc.
Stock up on foam tire swipes, these handy little foam blocks make applying any dressing fast and easy while keeping you clean and keeping your wheels and surrounding body panels free from any overspray.
Clean the tires really well first, then shove the spray nozzle into a tire swipe and load the foam up with some tire dressing, then apply to the tire.
Bury the nozzle right into the foam and infect the foam with dressing...
Here's a tip...
Note how I inject the tire dressing into the outer edges of the face of the foam applicator pad?
That to make it EASY to get the perimeter of the tire next to the rim.
Then rub the edge of the foam around the tire hugging the outer lip of the rim...
That's how you dress this hard to dress area...
The sidewalls are always the easy areas to dress...
A deep, dark shine...
On Autogeek.net
Flex Foam Tire Dressing Applicators - 3 Pack
Pinnacle Black Onyx Tire Dressing
Here's a tip...
On Autogeek.net
