How to be silicone free??
pricha00
I was reading an interesting thread here concerning some issues with some hazing and cloudiness on a finish that could be caused by some silicone contamination of either pads or microfiber towels. I have a feeling that I may be suffering something similar. When I apply my sealant it doesn't seem to lay down in some areas. The applicator drags along in some areas and applies no product in other areas. What do I wash my pads and towels with to eradicate any silicone residue? I saw some mention of Hi-temp washes. Any ideas where I could locate this product in Canada? The shipping from the US can be difficult and expensive so local is better for small purchases.
Thanks, Pat.
The key phrase was "apply my sealant". It may be something other than silicone. It could be any type oil or wax under it that can cause a smear fest. Rule of thumb, your sealant will only bond to fresh clean paint ( there are exceptions to that statement). Anyway something else to consider.
I am applying the sealant on a freshly polished surface. Usually the last step for me is XMT #1 on a white LC pad. Should I be doing the 50/50 alcohol/water wipe down before I apply the sealant?
Pat.
yes wipe down with 50/50 iso then apply sealent. your probably having troubles with the oils leftover from the xmt.
yes wipe down with 50/50 iso then apply sealent. your probably having trounles with the oils leftover from the xmt.
:iagree: worth a try. If it works you've got your problem pinpointed. Let us know.
there are good silicones and bad silicones, most of the time the hazing is associated with polish removal (failure to breakdown properly) or finish not being clean and clear for sealant to adhere to properly.
Not to highjack this thread, but what are bad silicones and good silicones? And which products has them.
See Good silicone / not so good silicone - detailingwiki
Silicone Removal:
Surface preparation- if previously applied products containing silicone have been used, apply a silicone oil and / or wax remover (Hi-Temp Prep Wash, DuPont PrepSol, Menzerna Top Inspection or Swissvax Cleaner Fluid) to remove as much of the silicon as possible before polishing
Polishing - when a silicon-free polish works on the paint surface it uses aluminium oxide particles, suspended in water and hydrocarbons and a mechanical process (polishing) to abrade the paint surface to the base level of the scratch. Silicon cannot be removed by mechanical means (polishing); silicone can only be removed with chemicals (solvents). If it is not removed the silicon mixes with the paint dust and polish powder and it creates a smear on the paint.
Menzerna quote: “It is impossible to remove silicon from a painted surface without using a chemical process so aggressive that it dissolves the paint. Wax and grease removers will chemically remove one layer of silicon off at a time but are unable to completely remove all the silicon. Tests by Dr Michael Hauber at Menzerna using a spectroscope showed the layers become thinner but the silicon remains.
Removing silicon completely can take place over time and involves a lengthy process of oxygen, chemicals, time and sunlight." There is a need to differentiate between swirl marks in the silicon layer and swirl marks in the paint surface underneath. Some polishes may appear to remove the swirl marks in the paint but are really only working on the layer of silicon, so the swirl marks in the paint surface remain unaffected by polishing".
Use Hi-Temp's Prep Wash to prepare a paint surface for polishing, compounding, wax and / or polymer sealant application (especially if changing from a wax to a polymer product) this is a water-based paint cleaner designed to remove all traces of silicone, oil, and buffing residue from any exterior paint surface, residue from polishing products accumulate in crevices, around handles, wiper arms, on trim, luggage racks, and aerodynamics. Hi-Temp's Prep Wash flows into these hard-to-reach areas and dissolves the build-up.
Hi-Temp's Prep Wash can be used to cleanse the finish before painting, and you can use it after buffing or levelling applications. It prepares the surface for the proper bonding of waxes, glazes and paint sealants. If this is not done properly, applied products may not bond, which will cause heavy streaking. It may be diluted, but is always used sparingly at any strength. Mist a cloth or sponge and wipe over the surface. Wipe dry with a clean towel. Hi-Temp's Prep Wash -
Anyone in Canada know where to get prep wash?
go to a body shop supply or good auto parts store and ask for Prep Sol....or equivalent..its a solvent cleaner that will remove any wax ...sealant ..silicone on paint....it goes under a few names....the Hi Temp prep wash is the same as Prep sol...
AL
