You can use polish like Menz 85RD, like previously mentioned. I would only use as needed and not every time you polish, and make sure you tape the edges. Did you try claying it? A IPA wipedown will clear up a lot of stuff, but that is not recommended a lot either. The alcohol takes off a small amount of the film(I was told), but it does work.
For maintaining the film. I use DP plex-all almost every time I wash it.
Is it a 3M Clear Protectant? If so, I use Plexus to clean it, and 3M Quick Wax to shine it up. The Quick Wax, P/N 39034, was originally designed for use on 3M films. It was only recently renamed to Quick Wax, but the P/N is the same as the orginal introduction.
I use Plexus on my window tinting (home and car) a well. Specifically designed for films as it contains no alcohol or solvents.
I have 3M clear protection on all my vehicles and do not have an oxidation issue. Oldest application is almost 6 years old.
I doubt you will be successful in removing scratches. And I wouldn't recommend using an abrasive on the clear film. If it bothers you that the film has scratches or nicks you may have to get that section of film replaced. I'm about to do that with my wife's car.
Good luck,
I don't have a DA, so no go wiht that, can I still use Klasse AIO as polish and SG as a sealant?I also have one on the BMW. Yes, you can use a DA with a finishing pad.
It gets the same treatment regarding washing & waxing as the paint gets, however when polishing I wouldn't use anything more than a polish such as PO85RD from Menzerna. Nano polish (extremely light or NO abrasives).
Wax, polish, seal, QD as you normally would the paint. The clear bra is one of the very best investments anyone can make in their car ....... congrats.
Hi Guys,
I have clear bra on all my cars, and I would like to know how can I clean it from oxidization and scratches? however I can't use DAs. Your thoughts are greatly appreciated!
Yes, Klasse AIO & Glaze Sealant would be fine.
I have heard that you can't use Klasse SG on anything else other than the paint, right?
