How to clean my pads?
Yes both the cleaning solution and the brush work very well.
Wash them in a bucket or a utility sink then rinse and squeeze out any excess water and the place someplace that doesn't have a lot of air-borne dust where they can dry. Place them upside down so the water drains away from the Velcro backing material.
First off, what type of machine/pads are you using? I assume you're using a machine and not just pads by hand..
There are many different ways to clean your pads depending on what you're using:
http://www.autogeekonline.net/forum/how-articles/20135-how-clean-your-foam-pad-fly-when-using-porter-cable-style-da-polisher.html
http://www.autogeekonline.net/forum/how-articles/20713-cleaning-pads-flex-3401-grit-guard-universal-pad-washer.html
And a video of Mike Phillips demonstrating the different "bucket-style" pad washers:
pad-washer
:dblthumb2:
Im going to be cleaning my ccs pads :D
thank you for the tips guys!
get the DP Pad Rejuvinator ... the size is perfect and you can mix small or large batches as needed depending on the amount of pads used.
