DetailingGeek
- May 9, 2013
- 21
Just picked up a Cadillac DTS.. It was pretty neglected. Cleaned up pretty well, but I'm having trouble cleaning some crevices in the interior... Here are the two problem areas:
The door panel pockets are cloth or thin carpet or felt. Not sure exactly what. I managed to clean them fairly well with a toothbrush sized brush and a vacuum. However they still have this nasty sticky feel.
Similar problem with the center console armrest & compartment, except it's worse because the brush is worthless since it doesn't reach far enough down, and it can't get in the corners. I need a dremel attachment or even a strong hand brush that can reach in there. Any suggestions? The lower compartment is pretty deep and hard to get at.
It also has the same stickiness, and a foul odor that I hope will go away (any tips for the odor in case it doesn't go away?)
I tried using my McCulloch MC1275 Steam Cleaner, but that didn't work either. (On a side note, I've been overall pretty disappointed in this model, but maybe I just need to get a stronger commercial one).
