how to coil an extension cord
VISITOR
Active member
seems like we all roll/coil up are extension cords one way or another, but this way seems to help prevent problems that you will encounter later...
I roll mine up like this.
There's a name for it, but I don't remember. It all comes loose quikly without any tangles and is quik to tie back up.
I have a friend who is a camera operator for a local TV news department showed me the over/under technique years ago. The cords/cables always lay flat and never tangle. With just a few minutes practice, it's really easy to do.
One of Mike Phillips pet peeves is the rolling of the cords in the garage.
i was told its called a contractors knot, idk if thats really the term but thats what i was raised to call it, i just googled contractors knot and the same pics and videos of it came up as well so id say its correct
We called it a daisy chain in the Marines.
Its the way we rolled up climbing/repel ropes.
Yea that sounds familiar. I think that's what I heard it was called.
i was once inspected by the fire depot and they called one extension cord connected to another daisy chaining.
Sprinkler fitters use that knot for extension cords. Problem with it is if you pull it from the wrong end you have a mess.
I was in the divers local out of Manhattan. We all took a rigging class and the way they taught to coil things up is over and under. When done right you don't get a$$holes in the lines or cords. After its coiled up, take one end and go around 3 times then you do do this little deal at the top to hold it all there. When its done you are holding one end of the cord.
don't know if the cords were already like that prior to coiling/rolling them up (the pic on first page) but they both look to have some (licorice) twisting in them...
Guys I am also in the professional audio business (commercial audio sound systems, Scott Hibbard Audio LLC Home) and have coiled probably no less than 10,000 cables in my 30 years in the biz (no kidding - sometimes as many as 100 per night during concert season. The ONLY way to coil a cord is the under/over method. Done properly this will guarantee that the cable never gets tangled. The key is the little twist of your fingers to "show" the cable the way as it goes over/under. Never use the around the arm method.
ScottH
At my parent's house tonight and had to use the extension cord. I was all excited because I watched that video yesterday. Long story short. The cord had so much memory from being rolled up a different way that I couldn't get the cord to wind the way I wanted it to.
HTTPS://youtu.be/eTpbh2zJGhA
That's the same exact video I learned it from! Lmao. That video has to be at least 2 yrs old because it's been a while.
And I'm not sure which knot eaglefan's referring to opening up the wrong way and having a mess, but this perticular knot is virtually impossible to open up anyway but the right way. It always opens up on the side of the plugs. I don't even think it's possible to open it up on the other end.
That's right.
We have up to 26 cords pulled at one time, all plugged in and buffers running.
Autogeek's Show Car Garage is wired to run up to 30 polishers at one time without blowing a fuse. Pretty cool and something most people don't consider when thinking about what it takes to hold a pro grade detailing class like we hold here at AG Comp Ready Classes.
Even tonight, we'll have 20 cords pulled for the Buick and the FJ40 we're buffing out starting at 5:00pm.
When the work is done, I teach my class to pull cords, that means get them off the floor and back on the cord cart and when they pull their cords we use the Cowboy Coil to coil them up. It's the only way to go to preserve your cords, avoid a huge tangled mess when you deal with so many cords and avoid kinking or twisting the cords.
We pull cords and wrap tools.
When we shoot our TV show and I have a team of guys, some that have taken my class and some that haven't, it's real easy to see who's taken the class when I say,
Pull cords and wrap tools
:dblthumb2:
Ive seen it a few times become an absolute mess and it takes forever to get undone. However Ive seen guys pull it apart no problem also. Im not saying its the wrong way to do it at all.
Dive hoses, welding cable, cords, rope, hogging line, everything that could be coiled up over/under was and had to be.
Never paid a lot of attention to storing away my extension cords. But the licorice effect did annoy me. It's funny how after I'm done using my pressure washer, I always use the over/under technique for my hose.
Thanks for the tip guys.
Sent from my SM-G928T using Autogeekonline mobile app
