Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
How to compound, polish and jewel paint to perfection using only the the rotary buffer
This class starts at 2:00 PM on Sunday
You must reserve your seat by calling Andre at 1-800-869-3011 x244
Class covers,
Here's my demo car for this class.
Note: These picture were taken months ago and since then something has happened to the paint, it's now filled with swirls and scratches. Were going to go over how to remove the paint defects and then jewel the paint to perfection using a rotary buffer.
1941 Chrysler Business Coupe
See you here!
Class covers,
- How to prepare a car when using a rotary buffer.
- How to buff off and edge without burning through the paint.
- How to pick up a bead of product using the 10 @ 10 Technique.
- How to use a rotary buffer to edge a panel.
- How to do precision or surgical buffing.
- How to use a wool pad and a compound to remove deep defects like swirls, scratches and sanding scratches.
- How to use a foam pad to remove holograms from the compounding step.
- How to use jewel paint to perfection using gold jeweling pads.
- How to clean pads the right way with a pad cleaning spur.
- How to use a pad washer to clean pads.
See you here!
