Re: how to determine what a wheel is made of
How to tell what the wheel is made of:
Steel or Aluminum is what 99% of your wheels today are made from. Steel contains Iron, and therefore a magnet sticks to it. Aluminum has no iron, and a magnet does not stick to it. Simple. Get a magnet.
If the wheel has a clear finish, you have to stay away from caustic cleaners. What is a "caustic" cleaner? Any cleaner containing a basic solution. I use "basic" as a chemical term (I am a chemist, among other things), meaning the pH is above 7. Think "oven cleaner" or baking soda or lye. Wheel and tire cleaners that are caustic contain Sodium Hydroxide or a different hydroxide compound that has a high pH like oven cleaner (not as caustic of course but still can burn your skin in some cases). Read the label of the product. It will at least say you need to wear gloves when handling the product, maybe wear goggles. Better labeling tells you about the hydroxide chemical in it.
To test a wheel for clear finish, there really is not a test. But if you buy Flitz metal polish, this can be used on clear coated metal and even on painted finishes and clear plastics such as lexan, so it is safe to use on clear finishes. I don't recommend using it for this purpose, however, except to take a small amount on a soft cloth and rub it on a small area of the wheel. If the cloth turns real black, you got an aluminum wheel that has no clear coat. If it doesn't turn black, you at least did not harm the clear coat.
