sweatthedetails
Member
- May 15, 2012
- 483
I've never tried simple or purple. I know they are easily available locally so that's a plus. I actually just bought 5 gallons of Stoners degreaser and it's comparable to the Meg's stuff, only much cheaper. Neither smell good per say but the Meg's is a more preferable scent while the stoners just has a strong chemical odor. The both dilute the same which is a must when using a lot. I don't think your supposed to dilute the green or purple so the cost efficiency really isn't there for me.
Jacksonville Auto Detailing - Home
www.facebook.com/DentsAndDetails
I may be slow, but I do poor work.
Simple green does dilute down and it does an okay job for me but not better than megs all purpose.I've never tried simple or purple. I know they are easily available locally so that's a plus. I actually just bought 5 gallons of Stoners degreaser and it's comparable to the Meg's stuff, only much cheaper. Neither smell good per say but the Meg's is a more preferable scent while the stoners just has a strong chemical odor. The both dilute the same which is a must when using a lot. I don't think your supposed to dilute the green or purple so the cost efficiency really isn't there for me.
www.JaxDetails.com
Wheel barrels are always extra unless it's a brand new carWhen I clean my wheels I always do the barrels too. You charge extra to clean the barrels? I consider it part of the wheel.
Fair enough, thanks for explainingI'm on the Westside. As for the barrels it's really a case by case matter. I build my packages based on an expectation of pay by hour. I never use the term "full detail" or "all inclusive" because these can mean different things to different people. My packages include the most popular items that people look for in a cleanup car. I know how long it will take me to do these packages on average. If the wheels are maintained to a degree then it will not take much longer to clean them. But if they have years of baked on crude that will add an extra 15 minutes a piece then yes I will need to charge for that hour. I could build that expense into my packages but wheel barrels being clean is not something my average client is really interested in.
