How to do it right??? From Guatemala
GeO2110
Hi, thanks for all the advise that give me in my effort to make my car brand new...
Last try I made holograms, or little swirl marks from my swirl remover, well after a long search finally found 3M UltraFina SE, so need and advise please..
Should i proceed like this or please let me know..
1. Wash my car
2. With swirl remover and LC Orange Pad remove the swirls, that is almost gone.
In this step i have a problem, i put a little polish in the pad, then in speed 3 of PC spread it, finally speed 6 work it. The problem is that the product dry so fast, that i thing i should spray a little water to make 2 passes, but i'm not sure.
The other question is that should i work it until it make a high gloss, or when turn transparent, that turns really fast at speed 6, let it dry and remove with a MF.
3. i thinking to use the ultrafina to remove the holograms with a white pad or should i use a blue pad???
4. Again with the white pad use final glaze from 3m, here i have another question, i check in videos that i should work it until make a high gloss, but it seem to not dry never, should i keep working it until it dry, or i putting too much product????
5. Should i use polish after this steps, i think not. But let me know???
Thanks for your commentary in advance...
From Guatemala...
:buffing:
If you are using ultrafina to eliminate buffer halograms. Put enough polish on the finishing pad to keep the entire area where you are buffing wet with a thin layer of polish. Then go over the area for 4 or more passes at between 1500 and 1800 rpm with a finishing pad. Wipe off the oily residue with a scratchless microfiber, then check the surface. If it looks good do the rest of the car repeating the steps above then apply the LSP.
Derrick
