Here is one of those odd questions that I do not see a lot . If you had a ceramic coating applied to your car , lets say car pro cquartz, then you maintain that coating with car pro reload every 2 months , but you are one of the many guys that may be using another product to boost your gloss even more everytime you wash your car , lets say a product like bead maker
What do you do after 2 months when reload has to be re applied and you just applied bead maker the week prior on your regular car wash. So bead maker is still on your paint .
Do you try to remove bead maker with some type of harsh soap or iron x , do you just apply reload on top of beadmaker ? , or do you just keep putting bead maker and forgot about reload .
This is where topping products on top of each other gets confusing to me . Specially if your last topper is a different brand
I have done both , just apply reload ( topper) after a good car wash , regardless of beadmaker being there or not , and then applying bead maker on my next wash . I have also used at least some type of harsh chemical to try removing bead maker to apply reload. I have also tried stop using bead maker for 3 weeks prior to reload application and hope for the best. At some point I even used elixir which is a version of reload, so it was easier to just apply reload, since they were both in the same family.
I see people all the time using a base coat and a topper , seems to be standard. If the base coat is something like a ceramic coating , its not to bad since you do not need to re apply that for a long time. But if the base coat is something like a 6 month sealants and your topper is use every week , then it gets tricky to me. Or if you are using a ceramic coating , a topper, and a drying aid, there is always that questions once you need to reapply the topper, how do I remove the left over of the drying aid to apply the topper every 3 months
How do you guys do it?, or do you guys just stay in the same family all together and find a QD that is using similar products than the sealant?
