Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
How to dry a foam pad after hand washing
After washing your foam buffing pads by hand the question often comes up,
How do I dry my foam pads?
Here's one way to dry your foam pads, please feel encouraged to find a way that works best for you.
Using a clean, dry cotton terry cloth towel or clean, dry microfiber waffle weave towel or any clean microfiber towel, roll your washed and rinsed pad up inside the towel.
Press the towel into the foam as you're folding the pad into the towel.
Then squeeze, squish and wring the towel which will force any excess water out of the foam and into the towel.
Afterwards, place your foam buffing pads upside down some place where they will stay clean where air can circulate around them and moisture can evaporate out of them.
Not a perfect method but it works...
