Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
How To - Finish Kare Paint Contamination Removal System
Here's what Finish Kare recommends for using their system...
Taken from here
1119 / 883 DECONTAMINATION SYSTEM COMPONENTS
The materials in this system are, alkaline, acidic and neutral, THEY MUST BE USED IN THE SPECIFIC ORDER.
Step 1 - 1119 Soil and Coating Remover
Finish Kare Soil & Coating Remover / Wax & Detail Pre-Cleaner is part of a four-step system to rid automotive paint of damaging ferrous metals and airborne contaminants. Using this system, you -the professional detailer - can prevent paint damage and create a truly clean, well-protected finish. It all starts with Finish Kare Soil & Coating Remover / Wax & Detail Pre-Cleaner.
Soil and Coating Remover is a fully biodegradable cleaner which is alkaline based with inhibitors for safe usage. #1119 removes outer surface rust, iron oxides, soil coatings, vehicle wrap adhesives while cleaning and preparing the surface for step two.
The Finish Kare Paint Decontamination System was developed as a method of removing paint contamination beyond what can be removed by washing or claying. If you are familiar with detail clay, you know it is capable of removing above surface contaminants that have bonded to the paint. The Finish Kare Paint Decontamination System is designed to remove what lies below the paint surface.
Airborne chemical compounds and ferrous particles - particles containing iron - actually penetrate the paint and create corrosive compounds that eat deep into the paint's sub-layers. This is a gradual process that often is not evident until it's too late. Claying or polishing only removes the particle, not it's effects, which are continuing to spread beneath the surface.
Finish Kare Soil & Coating Remover / Wax & Detail Pre-Cleaner is the first step in this system. It is a fully biodegradable, alkaline based cleaner with inhibitors for safe usage. It removes outer surface rust, iron oxides, soil coatings, and vehicle wrap adhesives while cleaning and preparing the surface for step two.
How-To use Finish Kare Soil & Coating Remover/Wax & Detail Pre-Cleaner
After using Finish Kare Soil & Coating Remover / Wax & Detail Pre-Cleaner, the outer paint will be stripped of waxes and silicones and all surface contamination. Paint contamination can be layers deep, so the Finish Kare addresses these layers step by step. After the outer paint layer is clean, Step 2 Finish Kare SIRR Steel, Iron Rust Remover will neutralize and remove ferrous particles.
It is very important to follow all four steps in the Finish Kare Paint Decontamination System in their prescribed order. The sequence of alkaline, acidic, and neutral cleaners helps counteract the effects of the paint contaminants.
The Finish Kare Paint Decontamination System is used by body shops for pre-cleaning prior to detailing and by dealerships for new and used car prep. It is proven to deliver a clean, glassy smooth vehicle that is protected from the harmful effects of paint contamination. No other is as fast and effective at removing multi-layer paint contamination.
Complete paint decontamination starts with Finish Kare Soil & Coating Remover / Wax & Detail Pre-Cleaner.
Step 2 - Finish Kare SIRR Steel, Iron Rust Remover/ Acid Based Cleaner consists of blended acids and inhibitors which actually open the pores of the paint allowing the ferrous particles to be removed by agitation. Additionally, #883 will enter the subsurface of the paint film and neutralize caustic compounds generated by ferrous particles that have penetrated paint film.
Finish Kare SIRR Steel, Iron Rust Remover/ Acid Based Cleaner deep cleans the sub-layers of auto paint to protect the paint from ferrous (iron-containing) particles. This preventative measure puts a stop to corrosion by neutralizing caustic compounds. No other method cleans paint as deeply as Finish Kare SIRR Steel, Iron Rust Remover.
Finish Kare SIRR Steel, Iron Rust Remover/ Acid Based Cleaner is Step 2 of the Finish Kare Paint Decontamination System. Step 1, Finish Kare 1119 Soil and Coating Remover, removes surface soil. Since paint contaminants penetrate below the surface, Finish Kare SIRR Steel, Iron Rust Remover opens up the paint's pores to release ferrous particles and to neutralize caustic compounds that have developed in the paint's subsurface. Ongoing damage is immediately stopped and future damage is prevented by removing the ferrous particles.
Remove paint contamination from deep within the paint with Finish Kare SIRR Steel, Iron Rust Remover/ Acid Based Cleaner.
CAUTION: Finish Kare SIRR Steel, Iron Rust Remover/ Acid Based Cleaner is for professional use only. Protective goggles, gloves, and clothing should be worn, and a first aid kit should be available in case of accidental contact.
Step 3 - Finish Kare 118 Super Concentrated Shampoo 31 oz
A heavy-duty highly active shampoo concentrate, non-clogging, non-hydrolyzing neutral soap system. #118SC when used with cold water quenches the paint surface which pops ferrous particles up and out of the paint system. #118 because of its special blend of chemicals will also neutralize acid rain surfaces as well as acidic contamination below the surface.
After decontamination the paint has been striped clean and left with no protection, so it is very important that a sealer be applied immediately.
Step 3 Prevents the effects of hard water and acid rain!
Finish Kare 118 Super Concentrated Shampoo has the slickness and the suds to safely wash your vehicle, plus water softeners and acid rain neutralizers. How many car washes can say that? Finish Kare Shampoo is clean-rinsing and will not strip wax. It could be the auto shampoo you've been searching for!
A great car wash has to be gentle and effective, safe on the paint but hard on dirt and grime. Finish Kare has accomplished all of the above with their Finish Kare 118 Super Concentrated Shampoo. This pH neutral car wash has excellent cleaning power to remove road grime and residues, yet it preserves the existing wax or sealant coating. Therefore, when you're finished washing, your vehicle looks clean and shiny.
Finish Kare 118 Super Concentrated Shampoo works hard to protect your vehicle's finish. It softens the wash water to help counteract the effects of hard water. You can feel the slickness of the lubricants! Acid rain neutralizers protect your paint finish from environmental pollutants.
Finish Kare 118 Super Concentrated Shampoo is Step 3 in the Finish Kare Paint Decontamination System. After using steps 1 and 2 to clean the paint, this gentle car wash restores a neutral pH to the paint and removes any cleaner or contaminant left on the paint. Always use a fresh wash mitt. Dilute 1 oz. per gallon of water.
This step is very important after using an alkaline cleaner (Finish Kare Soil & Coating Remover) and then an acidic cleaner (Finish Kare SIRR Steel, Iron Rust Remover). Follow up with Finish Kare 218 Poly Wipe Sealant Conditioner or Finish Kare 2180 Ultra to seal and protect the newly decontaminated paint.
Finish Kare 118 Super Concentrated Shampoo is biodegradable and safe on all finishes. Use it on your vehicle, boat, RV, ATV, or aircraft. The highly concentrated formula is a fantastic value.
Even with added water softeners and acid rain neutralizers, Finish Kare 118 Super Concentrated Shampoo is 100% clean rinsing. After washing your vehicle, what you'll see is a truly clean vehicle.
31 oz.
Step 4 - Finish Kare 218 Poly Wipe Sealant Conditioner
218 Poly Wipe Sealant Conditioner is formulated with amino functional and polymer resins. These resins chemically create a a cationic effect which allows them to plate to the surface of the finish forming a protective web allowing paint to breath and withstand temperatures in excess of 300 degrees. In addition, #218 does not contain any harmful silicones (i.e. dimethyl silicones), which are a wet, greasy evaporative, migratory component.
With a Patented Anti Static Agent, 218 A.S. forms a shield to Kill the attraction of dust As Well As Industrial Fallout That Is Magnetically Attracted To A Vehicle.
Finish Kare 218 Poly Wipe Sealant Conditioner combines paint cleaning with durable protection, all in a easy liquid formula. Finish Kare 218 Poly Wipe Sealant is a blend of anti corrosive, detergent-resistant polydimethylsiloxane copolymers, which provide great looks and long-wearing resistance to heat, water, and weather. Finish Kare 218 Poly Wipe Sealant makes car care maintenance-free!
Finish Kare 218 Poly Wipe Sealant Conditioner is a sealant for use on all finishes. The sealant removes surface accumulation and oxidation while penetrating and sealing the pores of the paint, giving great depth and trueness of color. The clean paint achieves a deeper gloss and looks healthier and smoother.
High melt resins offer prolonged surface protection and resistance to the elements, oxidation and detergents for months of maintenance-free protection. This means the Finish Kare 218 Poly Wipe Sealant Conditioner has a high melting point and provides great protection in sunny, hot climates. Regular washing is all it takes to maintain a clean, shiny finish. Finish Kare 218 Poly Wipe Sealant Conditioner lasts through rain, washing, and daily driving.
Finish Kare 218 Poly Wipe Sealant Conditioner is excellent for use on paint, fiber glass, gel coat, glass and chrome surfaces. Use it on your car, boat, RV, and ATV.
Finish Kare 218 Poly Wipe Sealant Conditioner is similar to Finish Kare Ultra Polymer Sealant but with more cleaning ability. Apply it with an orbital polisher or by hand. Use a soft foam finishing pad. Spread a small amount of Finish Kare 218 Poly Wipe Sealant Conditioner over about a 2 x 2 sq. ft. section until you've achieved an even coat. allow the sealant to dry for about 15 minutes. Buff with a clean, soft Cobra Indigo Edgeless Microfiber Polishing Cloth.
Finish Kare 218 Poly Wipe Sealant Conditioner cleans, seals, and protects the paint in just one step. Moderate cleaning action intensifies the shine.
Copyright ©PBMA - AutogeekOnline.net® All Rights Reserved
Taken from here
Finish Kare said:
- Dilute 1 part Soil Remover to 4 parts water.
- Rinse the vehicle to remove dust and loose soil.
- Wash with Finish Kare Soil & Coating Remover/Wax & Detail Pre-Cleaner and a wash mitt.
- Use light pressure to agitate the vehicle, working it in for 5-10 minutes.
- Rinse the entire vehicle with cold water.
- Dry the horizontal surfaces of the vehicle.
Finish Kare said:How-to use Finish Kare SIRR Steel, Iron Rust Remover/Acid Based Cleaner
- Apply it undiluted to the paint using a wash mitt. (Use a different mitt than the one used for Step 1.)
- Keep the surface wet.
- Work in Finish Kare SIRR Steel, Iron Rust Remover for 5-10 minutes using light pressure
- Dry horizontal surfaces and inspect them.
- Use a cellophane glove or a plastic sandwich bag over your hand to feel for impurities. If paint feels gritty, repeat Step 2.
Finish Kare said:How-to use Finish Kare 118 Super Concentrated Shampoo
- For the best results, dilute 1 oz. of Finish Kare 118 Super Concentrated Shampoo per 1 gallon of water in a 5 gallon wash bucket.
- Use a second bucket filled with clean water and use this fresh water for rinsing the mitt before reloading it with soapy water.
- This handy 2-bucket system, plus a soft wash mitt, will help you get shiny, swirl-free results with Finish Kare 118 Super Concentrated Shampoo.
31 oz.
