How to fix cloth seats with burns?
LincolnZephyr2006
Hey guys,
Does anyone know how to fix cloth seats with cig burns or hole? Any good DIY repair kits out there? I need to know ASAP! Thanks guys...
Take a razor blade and scrape the seats to remove some fibers and lint. Place a dab of super glue in the burn mark and place all the fibers you collected right on top to fill them up. Let the glue dry a few minutes and trim. Its not a perfect fix but it makes things look a lot better and cheaper than reupholstering.
Hmmm good idea... I will maybe try it. Has anyone ever used a DIY repair kit?
Depending on the vehicle, it is sometimes possible to get the fill in fuzz from the carpet. The advantage being that you can get the material form under a seat.
Like Lasthope05 says, it isn't perfect, but it does make a defect much less noticeable.
I went with Dr. Vinyl. They're a franchise, and I believe they'll come out to your home and fix it. I had a couple burn holes in my driver's seat that the previous owner had left (he was a smoker, but he only had the car for a couple months). I think it cost about $30 to get those few holes repaired. I went to Dr. Vinyl's website, and came up with this contact info for Dr. Vinyl franchisees in KY:
Linda and Mike Hook
Dr. Vinyl of Louisville, KY
(502) 447-6422
E-mail
Robert Popplewell and Donald Allen
Dr. Vinyl of Central Kentucky
(606) 787-0259
E-mail
Here are a couple pics of my seat. You can kinda see where the holes were. Maybe not the best fix, but better than a couple holes in the seat.
Hey Ciera.... It is actually for a customer car.... not mine! But thanks...
and also..... thanks for the suggestion guys. Do you actually take a razor blaze used for shaving or just the blade alone (like the one used for box cutters?) Anyways... I will give this a try! Should I scrape the burnt fibers around the edges first? Thanks again
You'll want to use a box cuter razor. Yes you'll want to scrape the burnt fibers out first to have a good base. After you've applied the glue dont press the fibers down hard. Just place them on top and lightly pat down. Let dry and trim. Repeat if necessary.
Its similar to this process but your not gluing a piece of fabric down but the fibers themselves.
[ame=http://www.youtube.com/watch?v=5zYCsiA0N5I&feature=related]YouTube - How To: Repair Carpet Burns[/video]
Do you actually take a razor blaze used for shaving?
I actually used a safety razor.
I trimmed as much of the burn area away as I could without getting into the undamaged seat fibers.
I also used a fabric cement from a fabric store rather than super glue.
GREAT IDEA!!!! (Thanks for sharing this) I have an older pickup w/ a couple of burns in the carpet I will try this on.
Thanks for the help guys, I appreciate it! I know this doesn't really coincide with the detailing arena.... but I am doing a car from a dealership and he requested to have the seats fixed! I will do the best I can!
PEP BOYS sells 3 different kits - One for Vinyl & Leather, One for Carpet and One for Cloth upolstery. All are $4.99 and work well. If you practice a little with them they are just about perfect ! You may have to really search for them because they are usually hidden on an endcap. Just ask an associate.
:props:
PEP BOYS sells a 3 different kits - One for Vinyl & Leather, One for Carpet and One for Cloth upolstery. All are $4.99 and work well. If you practice a little with them they are just about perfect !
Damn... just order the kit I listed above for $16 shipped! Does it look like that or is it different? Unfortunatley, I do not have a Pep Boys here!
:iagree:This is a sure way to match the color. I purchased one of the cheaper cloth repair kits. It has all the different colors of flock (cloth fibers). You can mix them until you have a near perfect match. Use Elmers glue in the burn and sprinkle the material in the area. The Super Glue dries real hard. IMO If it is deep it may take a couple applications. If you can find extra material under the seat or carpet. Cut it up fine and do the same thing. It works!
So, don't use super glue? I bought fabric glue and it is taking forever to dry... and it made the area look darker.... is this normal? I put on a minimal amount so over application is not the issue here. Should I try other glues?
PS- My kit has not come in yet, and this car has to be turned in tomorrow! This is why I am taking the carpet fill route.... thankfully I can with the suedeish material this Jetta has
Also... after it is done... will the spots seem a bit darker in color? It looks a lot better than the cig burns tho!
