Sprayed it a week ago. With a new devilbiss finishline 4
Psi at the wall was 100
Psi at the gun was 25
1.5 tip
Full fan and trigger
6" sprayed from the surface.
3 coats of clear
I'm afraid of burning through......or not having at least 2 miles left. I think this amount of peel is unusual. I don't have a clearcoat depth gauge
What I've used so far is is the 3m short throw da with trizact system starting at 1000, then going to 1500,3000,5000 3m polishing system.....white, black, blue with dewalt adjustable rpm buffer and foam pads.
How should I go about cleaning this up safely.
Gray scotch Brite and 3 more wet coats of clear?
Knock it down with 400 then 2 coats and a flow coat?
Flatten it some with 600 to 800 and 2 more coats of clear?
Or sand it the way it is until the peel is gone and buff it.....but will there be enough mils left for protection
Hood. Started with 1000
Roof
Bumpers are better
Door half sanded
Trunk
1.5 tip
3 coats of clear
Roof
Bumpers are better
Door half sanded
Trunk
