How to get rid of scratches/imperfections on front bumper?
Junkyarddogg
My front bumper is the area with the most imperfections for obvious reasons. But it stands out even more since its a black car. Anyone know what level of paint correction I would need to get rid of these? They seem to be embedded because if I run my fingers across it's smooth. Obviously the chips won't be able to be repaired.
If you have a polish on hand then try some on microfiber to see if it would remove the defect if not try compound then though if you don't have neither you could buy some meguiars ultimate compound, and or polish at your local auto parts store both are the same as meguiars m105 and m205
For all first time customers who receive a exterior detail I clay the front bumper. Then take my GG6 with a LC yellow cutting pad with M101. Then follow up with the LC white polishing pad with M205. I choose M101 over M105 because it works faster from what I've seen and the finishes are the same.
I previously tried Poorboy's black hole but since that's more of a glaze it didn't work. Before I jump to M101 or M105, I was thinking of going with a more conservative correction with less cut. Has anyone used poorboy's professional polish with any success? If that doesn't work then I will go with Meguiars or the Wolfgang twins.
