I need to strip the existing sealant (collinite) off for spray on sio based sealants like carpro reload/gyeon cure.
Usually I just use a polish (like Megs ultimate polish) and don't bother with an alcohol wipedown because it is not necessary with collinite. And any water would fly off and bead well before applying the sealant because the surface is clean (maybe from the oils from the polish also) but now I'm seeing here and
there that a clean clearcoat should sheet water slowly.
Thanks for your reply.
Accordingly:
I submit the below response for your
consideration. (Of course: YMMV.)
As to the initial application of Reload:
-It requires to be applied to clean, Wax and
solvent free surfaces.
-Polishing will ensure total removal of
Collinite's Waxes/Sealants. (I'd rather
use Meguiar's M205)
-Use a "panel wipe" afterwards to remove
any residuals from the polishing step.
-Do not apply any other Waxes or Sealants
over top of Reload. That way there'll be no
Waxes or Sealants to remove whenever you
want to re-fresh the Reload.
As to Cure:
"GYEON Cure is a versatile product that
makes it easier to maintain a Coated vehicle;
Cure is designed to work perfectly in conjunction
with GYEON Coatings." {~product description}
-As such, IMO, if no Waxes or Sealants are
applied on top of Coatings...then there should
be no Waxes or Sealants to ever be concerned
about, or to remove from Coatings.
