How to MAXIMIZE your DA Polisher
If you own a Porter Cable style Dual Action Polisher, this would include,
  • PC 7424
  • PC 7336
  • Meguiar's G100
Of which all of the above were sold for a time span of over 25 years, which means there are a millions of these tools in shops and garages across the world, then here's how to maximize their ability. Use small buffing pads.
First the reason for this article. The reason for this article is because the problem with these tools is that they have a hard time keeping foam buffing pads rotating under pressure.
It is even more difficult for these first generation PC units to keep a foam pad rotating under pressure as the pads become wet with product. The reason for this is because the wet foam acts to absorb and dissipate the power supplied via the Free Floating Spindle Assemble and the result is the pad will stop rotating and simply vibrate or jiggle against the paint.
Now here's why this is a problem...
Most people that get into machine polishing are doing so because they, like millions of other people, have discovered that removing below surface defects out of clear coat finishes is difficult and time consuming to do by hand. For more information on why it's hard to remove swirls, scratches and water spots out of clear coat paints by hand read these two articles,
The practical differences between single stage paints and a clear coat paints
The Free Floating Spindle Assembly - The Story Behind The Story...
Primarily due to the ability of "Discussion Forums" to disseminate information to large demographic and targeted groups of people, over the last 10 years more and more people have learned about the Porter Cable Dual Action Polisher and moved up from working by hand to working with an electric polisher.
Now this is key...
There are 4 primary things you can do with a Porter Cable Dual Action Polisher or similar knock-offs of this tool...
Correction Work - Removing swirls, scratches and water spots or etchings.
Polishing Work - Polishing the paint to a higher level of gloss and clarity after the correction step.
Waxing by Machine - Applying either a wax or a paint sealant by machine because it's faster and the machine is superior as compared to working by hand and working by hand is actually your 4 fingers pushing down on a wax pad.
Removing Wax by Machine - Not everyone goes this far but some people do prefer to remove dried wax or paint sealant by machine.
Now follow me on this... for the first two procedures, that is Correction Work, (removing defects), and Polishing Work, (that is refining the results of the correction step and maximizing clarity and gloss), you need the tool to maintain pad rotation while downward pressure is applied to the head of the tool.
Here's why this is important...
The way you remove swirls, scratches and etchings like water spots, also called "Below Surface Defects", is to remove the paint surrounding these types of defects until the highest points of the surface are level with the lowest points of the defects you're trying to remove.
In other words, the way you remove below surface defects is to abrade the paint until it is flat or level.
Paint is removed best, or if you like the fluffy way of saying this, swirls, scratches and water spots are removed best, when the face of the buffing pad is rotating over the surface, not just jiggling or vibrating.
When it comes to applying a wax or paint sealant, it's not important because at this stage of the game you're not trying to remove paint, (remove defects), you're just trying to spread-out a layer of wax or paint sealant and work it into the paint to whatever level is possible and jiggling or vibrating is perfect for this step.
Then if you want to remove dried wax or paint sealant by machine, then you do want the pad rotating again as that is how a microfiber bonnet around a buffing pad works best for removing a thin film of dried wax or paint sealant.
Back to the problem...
The first generation Porter Cable Dual Action Polishers are not very effective at keeping a pad rotating under pressure, especially pads that are thick and larger.
Thick foam acts to absorber and dissipate the power from the tool and we see this as no or reduced pad rotation. When a pad is dry, it rotates best, at least best to whatever its ability is for the size pad. As you work around a car and continually add more product to work over the paint, some of this product or liquid penetrates into the foam and the combination of foam and liquid acts to absorb the power even more than just dry foam alone.
Large foam pads mean more surface area in contact with the paint and the more surface area in contact with the paint the more power is necessary to rotating the face of the pad over the paint.
When everything is working against you, that is when the pad is large, the pad is thick and the pad is wet or saturated with product, the end results is very slow pad rotation and even no pad rotation.
How to maximize pad rotation for the correction and polishing step for 1st Generation Porter Cable Polishers
In a nutshell...
  • Small Diameter Pads - 5.5" diameter pads are the best balance of size and effectiveness.
  • Thin Pads - The thinner the pad, the less foam there is to absorb and dissipate energy.
  • Clean Dry Pads - Being able to switch to a clean, dry pad maintains tool efficiency for maximum pad rotation.
In detail...
This is not a recommendation in concrete, just a good general size recommendation because pad thickness and type are HUGE factors. For example, there are other pads for buffing besides the traditional foam buffing pads. One example is the Surbuf MicroFinger Buffing Pads which are very thin and for this reason you can maintain pad rotating fairly well with a 7" pad on a 1st Generation PC.
Generally speaking however, the 5.5" diameter pad is a good balance between too large and too small. It's true that a 1st Generation PC can easily maintain pad rotation with 4" diameter Spot Repair Pads but this is to small of a size to realistically buff out all the major panels of the average vehicle in a timely manner.
The thicker the foam the more the cushion and this might be good for a bed, or a couch or a chair, but when trying to maintain pad rotation with a tool that uses a Free Rotating Spindle Assembly, it's a negative feature.
"Thin is in..."
(Yes, you can quote me on that)
You don't want the pad too thin or there will not be enough material to conform to the shapes and contours common to the panels that make up a vehicle. For a really thin pad, you can use an Interface Pad which becomes the cushion for the thin pad and provides the safety margin needed for machine polishing delicate clear coat finishes.
In a perfect world anyone buffing out an entire car would have a collection of clean, dry pads available for their project and after buffing out a single panel, remove the used pad and switch to a clean, dry pad. A clean, dry pad can be a new pad or a used pad, but it's important that it's clean and dry.
Switching to a new pad for each panel of a car also prevents accidental swirls and scratches should a pad become contaminated from the previous panel. For large panels like the hood or roof of larger cars, trucks and s.u.v.'s, this it's completely acceptable and beneficial to use more than one pad per panel. Divide the panel into two sections and use a separate pad for each section of the panel.
Panel = A single door, hood, fender, etc.
Section - A portion of a panel
Here are my recommendations for 5.5" pads for 1st Generation Porter Cable Dual Action Polishers.
Note these also maximize the ability of 2nd Generation DA Polishers including,
Porter Cable 7424XP, Griot's Garage 6" Random Orbital Polisher and Meguiar's G110v2 and G220v2 which will be introduced some time in the future.
Lake Country
5.5" Flat Pads
The outer edge of the face of these pads is tapered so they are actually a little under 5" in diameter
Approximately 7/8" thick
5.5" CCS Pads
5.5" CCS Pad is right at 5.5" in diameter
5.5" Hydro-Tech Pads
5.5" Hydro-Tech pads are right at 5.5" in diameter
Approximately 1 1/4" thick
6" Kompressor Pads
The outer edge of the face of these pads is tapered so they are actually a little under 6" in diameter
6" Griot's Garage
6" Griot's Garage Pads are approximately 6 1/4" in diameter
Approximately 1" thick
6.5" Cobra Cross Groove Flex Pad
6.5" Cobra pads are tapered around the outer perimeter and measure approximately 6 1/4" in diameter
6.5" Meguiar's Pads
6.5" Meguiar's pads are slightly tapered around the outer perimeter and measure approximately 6 1/4" in diameter
Approximately 1 1/8" thick
5.5" Surbuf MicroFinger Pads
(For correction work only, must be followed with a foam pad for finishing)
Right on 5 1/2" in diameter
Approximately 3/4" thick
Re: How to maximize the ability of the 1st Gen Porter Cable Dual Action Polishers
Continued...
Meguiar's 6" and 5" Microfiber DA Pads technically referred to as
discs
(Note how thin these are by design...)
The cutting pad is approximately 1/2" thick before fibers matte down
The polishing pad is approximately 3/4" thick before fibers matte down
The 6" pads are actually about 6 1/4" in diameter
The 5" pads are actually closer to 5 1/2" in diameter
Products shown
Buffing Pads
5.5" Flat Pads
5.5" CCS Pads
6" Kompressor Pads
6" Griot's Garage
6.5" Meguiar's Pads
5" Microfiber DA Cutting Pads
5" Microfiber DA Finishing Discs
6" Microfiber DA Cutting Discs
6" Microfiber DA Finishing Discs
5" Backing Plates
Products shown
Backing Plates
The Edge Products 5" HD Backing Plate
Lake Country 5" Backing Plate
Meguiar's DA Backing Plate
3M Hook-It 5 Inch Dual Action Backing Plate - 5775
Besides using a small buffing pad, the next most important thing is to use good technique...
Using a DA Polisher - Part 1
[video=youtube_share;zUHRnHsSXZU]- How to remove swirls, scratches and water spots using a Porter Cable DA Polisher[/video]
Using a DA Polisher - Part 2
[video=youtube_share;fxwlWijdIxM]- How to remove swirls, scratches and water spots using a Porter Cable DA Polisher[/video]
Using a DA Polisher - Part 3
[video=youtube_share;9objUFdpsG4]- How to remove swirls, scratches and water spots using a Porter Cable DA Polisher[/video]
Most Important...
Here's how to do a "Section Pass" when trying to remove swirls, scratches and other below surface paint defects.
How to do a Section Pass
[video=youtube_share;Q70g83mnTn4]- How to do a "Section Pass" with a Porter Cable 7424XP[/video]
The Definitive How-To Article for Removing Swirls, Scratches and Water Spots Using a Porter Cable 7424XP, G110v2 or Griot's Garage Polisher
Porter Cable 7424XP
Meguiar's G110v2
How To Articles
Tips for working in warm/hot weather or direct sunlight
Proof You Can Do It! - Joe The Detailer - Black Porsche Turned into Black Pearl!
How much product do I use with my DA Polisher? -
The only problem I am having with my original PC is keeping the pad on the backing plate when the PC is cranked up to Speed 5. I'm using a Meguiars backing plate and CCS pads....any idea?
Put a line in marker on the backing plate, then you will know if its rotating.
Sounds like the Velcro on the backing plate is no longer hooking into the Velcro on the back of the foam pad.
Velcro wears out...
Somewhere I think I have an article or detailed reply on this topic.
What happens is the hook on the backing plate are shaped like the letter J and with use the curved part stretches out and looses grip strength.
Might be time to get a new backing plate.
This is the one I can recall.
There's a real science behind the shape and design of Velcro hook and loop fastening mechanism.
The hook side needs to be matched to the loop side and you can have hook and loop designs that don't actually match each other and when this happens the attachment strength is decreased.
Also, the more the hook and loop interfaces are pulled a part, for example taking a pad off a backing plate, the more the hook will become worn and performance will fall off. In other words Velcro wears out.
The hook side usually looks like the letter J as the hook wears the hook part or the lower part of the J will start to straighten out and thus you'll see a fall-off in attaching or stickiness to the loop side.
Maybe its time to get a new backing plate?
With all due respect:
Thanks for this thread. Looks like I need to switch to a Flex. I've been frustrated with my 7424 since the day I bought it. Needless to say I haven't used it much. I don't like the fact that I need to concentrate on keeping light pressure on it constantly & knowing that it WILL eventually stop spinning. & keeping this light pressure on it wont produce the results I need. I just want to pick up a polisher up & go & not have to worry if/when it will stop spinning.
Velcro wears out...
Good call. The backplate is at least 5.5 years old. When I first got the PC, I was using it a lot but now I barely use it. It's probably just showing it's age. I read that article about some pads not working with some backing plates...definitely could be another reason why they are not sticking too well. Or you are just BSing me to get me to buy a new backing plate and pads :dblthumb2: hahaha I'm a sucker when it comes to that! I'll use what I have to get my car ready for Mustang Week but I'll place an order before I do anymore detailing. Thanks for the advice!
This thread is the result of a question asked in another thread but it's a common or "Hot Topic" as I like to call it because a lot of people have the same issue.
When topics come up over and over on multiple forums it's time to write an article to address the issue and this is why a long time ago I created a forum group category called "Hot Topics". This thread is in the "How To Articles" forum group however because it's also a hot-to article, (but it is a hot topic).
One thing for sure, it's a fact that there are a zillion of the first generation PC out in the world and I can't count how many times I've answered a thread where the problem is "Pad Rotation and Large Pads".
And this is where I chime in and verify that you have a 7424 or a 7424XP because most of the time on forums I find people don't include the XP when referring to the new model, they just type 7424.
But I want to verify because I've read you're posts over the last year since coming to Autogeek and you're actually pretty thorough in your writing in posts.
Sad to say but everything wears out... including you and me... :)
I worked for a company once and the manufacturer of their backing plates chanced the "type" of hook used for the hook portion of the hook and loop attachment system and the pads literally would fall off of a brand new backing plate.
So there is a real science to hook and loop systems.
I'd like to play the "Funny Guy", but this job requires me to be the serious guy most of the time...
All the ones in the picture above work well, a work of caution about the 3M brand, whatever the hook style is they use it's grabs like nobody's business, it's attachment is strong enough that it can wear out the adhesive used to hold the loop interface onto foam pads.
So anyone that gets a 3M backing plate should really practice pulling their pads off carfully...
Thanks Mike. I appreciate all the advice.
Interesting article. Luckily for me my Gen-I PC (actually a Meg's G100A) has a lifetime warranty; being 8-9 years old now and very well worn, the bearings are getting pretty much shot and squeal whenever the machine is stopped.
I keep intending to call Meguiar's to have them replace it with a G110v2, but never get around to it since most of the work I do is handled by the Flex 3401 and 3403 polishers that are also in my toolbox. Just picked up the new Unigrit machine sanding system during the 4th of July sale though, so I'm probably going to need a traditional DA that's in better shape sooner than later.
Hello everyone. This is my first post to AG. I have read Mike's article and found it to be very disheartening. I had my heart set on ordering Meguiars 7inch 2.0 pads but now I'm having doubts. I currently have a PC 7424 (not XP) and 6 Cobra Cross Cut pads (2 orange, 2 white and 2 red). I'm new to detailing and feel comfortable with Meguiars products and was going to try their pads as well. Now, I am thinking about going with Lake Country pads. Here is my question, which CCS pads best match the Meguiars W8207 Yellow pad and the W9207 Black pad for cut or finessing? Thank you.
Yeah I was starting to wonder why i can't get the same results as others with similar products and pads. I have a older 7337. I have the 3m backing plate (with the marker line) and I use the ccs 5" pads. I just can't cut some of the stuff needed for correction on customer (friends cars). Thought it was me. Went back, reviewed and read. Basically found that for everywhere a video says use setting 4 then I needed to move to 5 or even 6 to acheive similar results.
Either way...its time to upgrade!
The white colored foam pads in the LC line are comparable to the yellow foam polishing pads in the Meguiar's Line and the black or gray foam pads in the LC line are comparable to the black finishing pad in the Meguiar's line.
The first generation DA Polishers were good and hundreds of thousands of cars have been polished out with them successfully...
The new second generation DA Polishers are even better...
If you ever watch how I craft some of my sentences when I write you'll notice I always leave room for new technology, nothing stays the same... there are companies out there always pushing the envelope whether it be with tools, pads or chemicals...
What can't be done today, will be done tomorrow... just wait and see...
Thanks Mike. Thanks Detail.
Mike:
Not to dig up an old thread, however I simply must thank you for posting this.
Two years ago I bought a PC and the Edge 6" Pad kit, and found even with proper technique it would take what seemed like forever and a day to two-step polish a Civic with soft paint. Partially thanks to this I have used the machine very little in the past 2 years.
Now I know exactly what the problem was and why the pad would so easily stop rotating. Does the XP version have near as much of a problem turning a 6-6.5" pad? At this point I don't know what I would replace (machine/pads/both). I really wish I had known this when I ordered.
Thanks again! :props::props:
