Nick McKees37
McKee's 37 Product Support
- Jan 6, 2011
- 7,265
The picture of the Corvette you see above is not relevant to this article. There, I said it!
Now that I have your attention, I'm going to demonstrate two very quick and easy ways to clean, maintain and enhance glass coatings using two of my favorite glass care products.
What is a glass coating?
A glass coating is generally a silica, nano, or resin-based product that is designed to form a molecular bond to glass surfaces. Glass coatings repel rain, sleet, snow, ice and virtually anything else that plagues your vehicle's windshield from every day use. While the most popular application for a glass coating is the windshield, they work equally well on side windows, mirrors, and more.
Examples of a glass coating
Here are a few of the most popular glass coatings:
- Detailer’s Glass Coating
- Optimum Opti-Glass Coating
- GTechniq G1 Clear Vision Smart Glass
- Wolf’s Chemicals Glass Guard Nano Glass Sealant
- CarPro FlyBy30 Windshield & Glass Coating Kit
Proper Maintenance
Glass coatings are a blessing for anal retentive enthusiasts that cringe at the thought of a dirty windshield, because they make cleaning your glass so much easier. FYI, I fall into that category; I hate, hate, HATE dirty glass. Did I mention I can't stand dirty glass? Now that I got that off my chest, let's move on.
The biggest mistake most people make after applying a glass coating is maintenance, or lack thereof. In order for a glass coating to cause water to bead up and WOW the passenger sitting next to you, your windshield needs to be cleaned on a regular basis. Road film and airborne contaminants make their way onto your windshield (and paint!) every time you pull the car out of the garage and take it for a spin. If your car sits outside 24/7, then it is constantly bombarded by the aforementioned airborne contaminants and, even worse, bird droppings! All of the above hinders the coating and its hydrophobic properties. By no means is a glass coating a "set it and forget it" type of thing. Proper maintenance is key.
Nick's Maintenance Plan
If you've ever read any of my previous articles, you know I'm an advocate of the saying "work smart, not hard." That couldn't be any truer for glass care. I don't like cleaning glass, and I'm not particularly good at it, so the fact that my windshield is (always) coated and that I use the proper products to maintain it, allows me to focus on more important aspects of car care and detailing - like how clean my wheels look.
I use three products to clean and maintain the coated windshield (DP Glass Coating) on my daily driver - 2010 Mazda 3.
- Pinnacle Crystal Clear Glass Cleaner with Water Repellent 32 oz.
- Pinnacle GlassWork Windshield Washer Booster
- Waffle Weave Microfiber Glass Towel
Pinnacle GlassWork Windshield Washer Booster is an advanced additive for your windshield washer fluid. It doubles the cleaning power of regular windshield washer fluid while creating a much slicker washer fluid that is less prone to streaking and smearing. Its formula is highly concentrated which means one 16 ounce bottle of concentrate treats 16 gallons of washer fluid! It is perfect for removing built up road film, dirt and grime to maintain the protection and hydrophobic properties of your glass coating.
Pinnacle GlassWork Windshield Washer Booster is packaged in a 16 ounce bottle that features a built-in measuring cup. This allows for accurate product measurement.
Simply squeeze the bottle until the fluid reaches the 1 ounce mark, locate your windshield washer fluid reservoir, and dispense!
Use as needed - Pinnacle GlassWork Windshield Washer Booster will not negatively affect your glass coating. It will actually make your glass coating perform better because it removes road film and contaminants, leaving the surface smooth again.
Best part? Pinnacle GlassWork Windshield Washer Booster doesn't leave a film or a build up of gunk on your windshield wiper blades.
Your search for the best glass cleaner is over. I can't tell you how many times I've said that sentence to an inquiring customer looking for a dumby-proof glass cleaner. Pinnacle Crystal Clear Glass Cleaner with Water Repellent removes dirt, grime, and road films while depositing a water repellent coating. Since this glass cleaner is alcohol free, it won't slowly degrade your glass coating over time. The built-in water repellent boosts and extends the hydrophobic properties of your glass coating.
Application is simple: spray directly onto the surface and wipe clean with a Waffle Weave Microfiber Glass Towel. After the area is cleaned, lightly buff it with a second clean, dry Waffle Weave Microfiber Glass Towel.
A lot of people ask "what's so special about the Waffle Weave Glass Towel?" The weave, of course! The Waffle Weave Glass Towel has over 220,000 fibers per square inch and a soft 75/25 blend of microfiber. Tiny spokes in the individual fibers, too microscopic to detect with the naked eye, lift and trap dirt and moisture, while gently buffing the surface to a shine.
That's it!
Maintaining the water beading and sheeting properties of your glass coating is easier than you think. Clean the windshield regularly using Pinnacle GlassWork Windshield Washer Booster to prevent road film and grime from bonding to the windshield. Once every week or two quickly go over the windshield with Pinnacle Crystal Clear Glass Cleaner with Water Repellent to further increase the water beading and sheeting properties of your glass coating.
Because I'm such a glass cleaning junkie, I put together a money-saving combo that includes everything mentioned in this article at a ridiculously low price.
Pinnacle Perfect Glass Care Combo
