Nick McKees37
McKee's 37 Product Support
- Jan 6, 2011
- 7,265
Aftermarket automotive accessories such as premium wheels, expensive summer performance tires, chrome exhaust tips, bed liners, and tonneau covers are all investments that shouldn't be overlooked when caring for your vehicle. Just like your paint, these accessories and add-ons need to be properly maintained to ensure that they look, and perform as they should.
One of the most popular accessories for trucks is a tonneau cover. Not only do they enhance the appearance of your truck, but they also provide protection for goods that are stored in the bed. While tonneau covers look nice from the factory, the protective coating applied at the factory does wear off over time and to keep the tonneau cover looking new and protected, it needs to be maintained just like any other aspect of your vehicle.
Wolfsteins, the leading manufacturer of Raggtop Convertible Top Care Products that are endorsed by Haartz and Roll-N-Lock, manufactures a kit that's designed specifically for vinyl tonneau covers. The kit includes a Tonneau Cover Cleaner and a Tonneau Cover Protectant.
The Tonneau Cover Cleaner is a non-toxic, pH balanced, biodegradable formula that's safe on all surfaces. The cleaner can safely be sprayed on paint, glass, and chrome without causing any damage. Dirt, grime, and bird droppings don't stand a chance with the Raggtop Tonneau Cover Cleaner.
The Tonnea Cover Protectant provides excellent UV protection against fading, cracking, and hardening. This patented formula can be used on all vinyl, plastic, and rubber trim. It contains no silicone, does not streak, and will enhance the appearance that's being treated. A tonneau cover treated with the protectant will be easier to clean and maintain in the future. Each application lasts several months.
For this demonstration I grabbed the keys to the largest truck in the parking lot with a tonneau cover. This tonneau cover has not been properly cleaned, or protected, for several months. Although each application of Raggtop Tonneau Cover Protectant lasts several months, for best results it's ideal to re-apply every 3-5 weeks. After the initial coating is applied, it takes much less product if maintained as directed.
You can clearly see how dull and tried out the tonneau cover is. It's not pretty at all, and takes away from what is otherwise a great looking truck.
