Jeff at Gyeon
- Aug 15, 2016
- 83
Good Day Good Day,
I thought I'd start a discussion on GYEON quartz Q2 Rim with a bit of How To. GYEON Q2 Rim is formulated specifically for wheels, exhaust tips, and any other high temp areas that you want to keep well protected.
So why would you want a quartz coating on your wheels?:
- Long term protection, you should see up to a year out of a single layer of Q2 Rim
- Protection from heavy brake dust
- Protection from heavy winter driving where salt and mag chloride will build up
- Easy wash maintenance on intricate wheel designs as the surface will want to release dirt and contaminant
What makes Q2 Rim a good choice?:
- Easy application. Wipe on and wipe right off.
- High temperature tolerance-up to 1400 degrees F
- High gloss finish on painted wheels
- Increase in "richness" and very healthy sheen on matte and satin finished wheels but will not add much gloss
How To: GYEON quartz Q2 Rim
First, we want to ensure we have a perfectly clean surface to work with. These Tesla Model S wheels have already been cleaned with GYEON Q2 Iron. Next, give each wheel a thorough wipe down with GYEON Q2 Prep. Q2 Prep will remove all of the cleaners and lubricants from the previous stage of cleaning, whatever that may be, and leave a perfect surface in which to coat.
I'm using a GYEON Q2 SoftWipe here for Prep removal. I like a very plush towel for this process to absorb and remove the Prep and the material it is breaking down. But any high quality and brand new microfiber will do. We want to make sure the towel is absorbing the material we are asking it to remove. So remember to flip sides often and use multiple towels if necessary to make sure we aren't transferring material from one wheel to the next.
Once the Prep stage is complete, it's time to apply Q2 Rim. A little tip, when working on wheels it is next to impossible to use the Foam Applicator Blow and Suede as a combo, and just as hard to hold just the Suede in your hands without dropping it every two seconds. So I pull out the rubber band trick. Wearing nitrile gloves so the coating doesn't come in contact with my skin, I fold the Suede in to a nice small square and rubber band it to my index finger. This makes for super easy install and ensures I get in all the cracks and crevices.
Next I apply a fairly generous amount of Q2 Rim to my finger applicator and start applying to the Wheel. I like to cut the Wheel in to quarters, and work one at a time. So I'll apply Q2 Rim to the upper right quadrant say (from 12 o clock to 3 o clock), and then remove immediately. The only time Rim isn't a joy to install is if it is left on too long. The GYEON coatings perform their initial bond within 3-5 seconds. So Rim can be removed anywhere from 15-20 seconds up to about a minute depending on installation environment. With all coatings, the higher the humidity the faster the coating will release its solvents and start to "flash", so the faster it should be removed.
Once applied, I remove with a second GYEON SoftWipe Towel.
GYEON Q2 Rim should be a fairly straightforward and easy application. You can apply it to any wheel finish safely. You can apply it to exhaust tips as well. It can be layered up to three layers, and once layered delivers some very tight water beading characteristics.
The biggest points to consider when applying Q2 Rim:
- Make sure the Wheel is well cleaned and prepped
- Use high quality and brand new Microfibers to make the job as easy as possible
- Check the humidity, if high then plan on removing the product a bit faster
- Work in quadrants so your install is controlled and you don't miss any intricate areas
Hope this helps! Glad to answer any questions and would love to hear how everyone is using GYEON Q2 Rim!
