How long has it been there?
if its fresh wd-40 will help or a soaked mf with water and push it against the spot and let dwell for a few to soften then wipe away
if its been there for more than a day then it will take longer to remove.......using the above tips.
sometimes a plastic razor blade will help but be carefull.
once removed some spot polishing may be in order to fully remove the stain.
Been on for about a year.
