Every year it’s the same struggle with the expired registration sticker that you put on your the license plate. At least in Florida, when you renew your car’s registration, you get a small yellow sticker with the expiration month and year. I always try to take off the old one, but I think they’re designed to be almost impossible to remove in one piece so they can’t be peeled off and put on another car.
Has anyone figured out an easier way of taking these off? I spent 25 minutes the other day trying to get it off. I ended up using a flat head screwdriver and gouging the hell out of the plate. I probably could have taken more time and been more careful, but i wasn’t in the mood. I’ve seen other cars where they just put the new one on a different spot on the tag so they end up with 10 stickers all over it. I don’t think that’s they way it’s supposed to work.
I also had the thought that maybe these would be easier to remove if you just put the new one on top of the old ones so you build up a thick layer and then after a few years, they’ll all come off in one piece. Kind of like Plastidip which is easier to peel off if it is applied with many layers.
