How to remove glass coating to add another?
mets2010
I have a coat of wolfs glass coating on a car and wanted to try the tech g1, i was planning on using g4 polish, will that remove any remnants of the wolfs or is there another step that needs to be done?
Yes, I would guess G4 would remove Wolf's Glass Guard. I have used CarPro CeriGlass to remove Wolf's Glass Guard with no problems.
G4 will remove it. Follow it with a wet towel to remove the residue, and then I spray the glass down with IPA to remove anything that may remain. Then you're good to coat.
