Outside of what Angelo posted above, I have removed ink from seats with Optimum Power Clean before, if you have any of that. If not you could try another APC (diluted properly).
DLB
do you need to dilute powerclean in order for it to work safely on the leather?
According to mark and chris, no you dont. I usually use it at 3:1 with good results. Sometimes I even water it down more at around 10:1 on leather that isn't in horrible condition. I like to use the least amount of product possible because I'm cheap/frugal. Opc is an amazing cleaner. As with everything, try a hidden test spot first to see how it reacts.
