Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
How to remove overspray while washing your car
Last Saturday we wetsanded a 1929 Model A Streetrod. The car arrived covered in dust. It was so covered in dust that I didn't think using a waterless or rinseless wash would work well enough to thoroughly clean all the cracks and crevices so I chose to wash this streetrod instead.
My default method of washing cars is to use a foam gun. I like how it slathers on a layer of foam plus it makes washing fun and more interesting in pictures. So first we foamed the Model A and then did a normal wash job using the Alien Worm wash mitts, also my favorite for doing a Prep Wash.
Using the 1/2 gallon foam gun to foam down a streetrod
Loosening all the dirt and dust with Microfiber Chenille Wash Mitts
AFTER THOROUGH RINSING OF THE LOOSENED DIRT - Re-foaming the Model A for the decontamination step.
Using Nanoskin Wash Mitts and Nanoskin Towels to rub off the overspray paint using the foam as a lubricant.
Final comments...
If you've always used detailing clay after you've washed and dried your car, the above is a way you can do the same thing while saving steps and in my opinion, doing a better job.
On Autogeek.com
Autogeek Quart Foamaster Foam Gun - $59.99
Autogeek Half Gallon Foam Gun - $69.99
BLACKFIRE Foam Soap - $24.99
BLACKFIRE Foam Soap - 1 gallon - $59.99
Make your life easy
Get Brass Quick Connectors to use while washing your car
Single Brass Connector Shut Off Valve - $7.99
Brass Quick Connector Set - $9.99
Once you have the Brass Quick Connector on the end of your water hose, if you have more than one water tool, for example a foam gun and a water sprayer, then you'll want and need more Brass Male Quick Connectors. Here's a 3-pack
Brass Male Quick Connects 3 Pack - $12.99
Nanoskin products
What's cool about these is if you drop one on the ground - instead of throwing it away like clay you can simply rinse it off and continue using it. With clay - you must throw it away.
Nanoskin Autoscrub Handy Towel - $29.99
Nanoskin AutoScrub Fine Grade Wash Mitt - $49.99
Nanoskin AutoScrub Medium Grade Wash Mitt - $49.99
Nanoskin Autoscrub Towel – Fine Grade - $59.99
Nanoskin Autoscrub Towel – Medium Grade- $59.99
Drying off the water to avoid water spots
There's a million ways to skin a cat or dry a car - here's one that's simple and fast and you can wash these towels and use them over and over and over and over....
3 Pack The Supreme Guzzler Waffle Weave Towels, 20 x 40 inches
Final comments...
On Autogeek.com
Make your life easy
Nanoskin products
