Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
How to remove oxidation - 1976 Sleekcraft Jet Boat
Anytime I get questions via e-mail, a PM or a FB message I prefer to invest my typing time where
A: It's easier for me to share links, pictures and videos.
B: More people can read and thus benefit from the information. (no just one set of eyeballs)
The reality is, most people that contact me found me via an article I've written or a reply I've written on this forum. The thing is, instead of figuring out that the whole reason they are contacting me is because they found me via an article or answer I wrote on the forum that they to should bring their question to the forum because not only will that help them.... but it will help a future "them". If I answer everything in a private e-mail or other touch point, no one would find and contact me. It's a cycle or pattern that repeats as long as everything is shared in the public domain.
The above is kind of wordy but re-read it slowly and it will make sense.
So I get an e-mail asking,
Hi Mike...
Say I bought a kit buffing kit from autogeek in anticipation of bringing my newly acquired 1976 Sleekcraft Jet Boat back to life.
I have read your book and viewed a few of your online videos. Question...
If I sent you some pictures of the condition of my boat would you give me your opinion what I should start with first...heavt cutting or Wet sand... Etc.
Great questions Mike
Here's the pictures you sent me,
Here's the boat - very cool boat by the way...
Here's the oxidation...
First - this is what's called a large metallic flake gel-coat finish which is popular with boats from the 1960s and 1970s.
Because there is an actual "flake" in the gel-coat - YOU MUST BE VERY CAREFUL when compounding or worst-case scenario, sanding on this kind of finish and you will sand INTO the flake. You don't want to do this as not only will you expose it and cause worse oxidation down the road but the surface will no longer be smooth but coarse as you can feel the flake.
The oxidation in the pictures doesn't look too bad as I've seen worse but there are areas where the gel-coat has turned white.
If this was a NON-metallic finish I would recommend machine sanding. Because it is a large flake metallic finish I would start with just compounding and foam pads.
If it were my boat and out in the garage outside my office I would try,
Then chemically strip and the apply the new GYEON Marine Gel-Coat Coating.
The above is a portion of what I teach in my 2-day boat detailing classes and the boats always look BETTER than new.
Hope that helps and feel encouraged to join our forum, this is where I answer questions. Email and Facebook messaging are okay, but the forum is a LOT more powerful. (think about it - it's how you found me in the first place)
Click here to join the AutogeekOnline.net car detailing discussion forum - THE best forum on the Internet
Hi Mike...
- FLEX 3401
- RUPES 7" Blue Coarse Foam Cutting Pad
- Marine 31 Captain's Compound/Polish
