Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
How to remove scratches in glass - Wiper Scratches from Beach Sand
I've buffed a lot of glass in my life and if you actually want to remove scratches "in" the glass you need a glass polish that contains cerium oxide and make sure the directions state it's recommended and approved for use with a rotary buffer to remove scratches out of glass.
Tip
Don't test or experiment on the driver's side of the glass, at least not in their field of view. Just in case the polish and/or process doesn't go to plan.
Here's a little Tape-Line Before and After I did to a Honda windshield that's parked outside all the time.
This windshield is extremely scratched over time from beach sand being dragged across it from the wipers. This is common to cars in coastal areas.
These are deep scratches in a 2004 Honda that has spent it's entire life parked outside in Stuart, Florida.
Here's the same windshield and the same exact location as above...
Glass Polishing is very messy
Just for anyone reading this into the future... glass polishing is very messy. Do yourself a HUGE favor and break out some old bed sheets or "something" and cover as much of the car as you can...
See my thread here...
How to remove tiny pinhole pits in glass windows using a rotary buffer
To remove scratches in glass you need,
Myself and others have had good luck using CarPro Ceriglass with the CarPro Rayon Glass Polishing Discs.
NOTE: The CarPro Ceriglass "polish" states right on the label and on the webpage that it does in-fact use Cerium Oxide.
CarPro Ceriglass Glass Polish 500 ml
Here's a screenshot I just took highlighting the pertinent information with red circles and lines.
Here's the link to the CarPro Rayon Glass Polishing Disc
CarPro Rayon Glass Polishing Pad
And a screenshot highlighting the pertinent information...
IMPORTANT
From experience, I'd say glass polishing, specifically removing scratches out of glass without leaving scratches behind in the process is an advanced procedure. It's not a project to tackle without first doing due diligence in your research.
Further Resources
You can read Nicholas's article on how to remove scratches and scuffs that are IN glass here,
Autowerx Ceriglass Guide
How to reduce the mess...
And to make the job a LOT LESS MESSY read my article here,
Glass Polishing Water Spray Bottles at Autogeek
The spray bottle in my hand is the 4 ounce bottle and works best for most people.
Tip
- A polish that contains the abrasive Cerium Oxide and the label should state the products is safe for removing scratches "in" the glass.
- A glass-safe glass polishing disc
IMPORTANT
Further Resources
