TROLL
- Jul 10, 2012
- 25
Hey Mike, been a while, hope you've been well and I'm sure you've been keeping busy.
I recently purchased a "project" RV -- a 2007 Winnebago View. The exterior has been maintained at an average or below average level so I'm looking to give it a thorough detail to give it a good fresh start and make the outside look its best.
(NOTE: I was just told that the previous owner used Zex floor wax on the RV as it sounds like a lot of people do, and I suspect it may darken / hold in dirt / be difficult to remove.)
Couple questions:
1) I've found small gray spots on the sides of the RV that aren't cleaning off, and they're not polishing off either.
I've just tried normal car wash soap and a mitt followed by an orange pad and M105 just on a test spot to see how it responded. The surface shined up but the spots remain. Any best way to try and remove these?
spots in fiberglass -- they get more dense higher up on the walls of the RV
polished area with spots remaining and my grubby hand for size reference
2) Also, on the roof there's a lot of noticeable discoloration. I suspect this is from the Zep. I was scrubbing with mild car wash soap and using a wash mitt as well as a pinnacle tar and bug sponge and Barkeepers Friend which does have a mild abrasive in it to try and get off some stray silicone and other spots of buildup. If I scrub enough, it looks like I lift the outer darker layer off and find a lighter layer beneath. Before I go further, I wanted to see if this is a stubborn layer of dirt/oxidation I'm removing, or an important layer of the fiberglass that I shouldn't be messing with.
this was after a light wash
View attachment 63989 View attachment 63990
closeup of an area that was scrubbed more with Barkeepers Friend where you can see a dirty layer coming off and a cleaner whiter layer being revealed
the front of the RV roof where it seems something was applied that resulted in a darker finish (Zep?)
(also some delamination and light cracking around the sides, which is probably a whole different thing to deal with)
I see that Zep has a "remover" chemical and I'm wondering if I need to do this step also, or if there's another way to be sure I'm stripping down to a clean surface that I can work back up from.
3) Bonus question -- is it time for me to get a wool pad before I dive into this? I'm polishing with a PC7424.
4) Bonus question #2 -- want to place any bets on whether I'd be able to remove the vinyl decals and be able to polish out any ghosting left behind? I don't have strong feelings about the decals so I can leave them, but they're in fair condition at best so I've thought about it.
Thanks!
Bryan
Couple questions:
Thanks!
Bryan
